1690Views10Replies
Author Options:
"5 volt limit" circuit? Answered
Is there a circuit that will take a range of voltages and make all of the voltages that are over 5 volts be 5 volts
like so:
3.5 => 3.5
4.2 => 4.2
4.9 => 4.9
5.1 => 5.0
6.3 => 5.0
steveastrouk
steveastrouk
Best Answer 10 years ago
Yes, its called a level clipper. The easiest way is show in the circuit for my "car-bar duino" board,  in the top right of the schematic
This clamps the input to the supply rail or ground +1 diode drop.
Steve
flybye22
flybye22
Answer 10 years ago
does that mean that i wont be able to clamp it at exactly 5V? Also, what diodes did you use, i gave the instructable and schematic a quick look through and did not see parts anywhere.
steveastrouk
steveastrouk
Answer 10 years ago
Not critical for any component really. It depends a little on just HOW much higher than 5V you go, if you're expecting no more than another 5V, say 1-5K. Steve
SoloUnNick
SoloUnNick
8 years ago
Hi, I'm interested to Jayefuu's circuit, but with 4,6-4,7 volt limit.
Is it possible to reduce output voltage, changing resistances?
Zener diode from GND to 12V....or from 12V to GND? I'm sorry but I am very ignorant
Jayefuu
Jayefuu
10 years ago
This circuit clamps the output between 0 and 5V. Used it on my final year project. Change the resistors if you have a different supply voltage.
steveastrouk
steveastrouk
Answer 10 years ago
That's funny I have a circuit just like that one.....
ARJOON
ARJOON
Answer 10 years ago
me also. I think Google is the responsible for
Jayefuu
Jayefuu
Answer 10 years ago
I thought since I'd already drawn the diagram I might as well pass it on :D
steveastrouk
steveastrouk
10 years ago
Better to replace R2 with a Zener diode. Steve
steveastrouk
steveastrouk
10 years ago
You can also just put a limiting resistor and a 5V zener diode at the input. Steve
