645Views15Replies
Author Options:
50cc longjia lj50qt 3-l wiring fault? Answered
my sons Chinese moped when switched on will show the fuel gauge level and indicators work, but once he set off moving they fail and when he stops again they work ok. does anyone have any suggestions where I can pin point the fault or general area I need to be looking for the problems. I can fix most things but wiring is my weakness.
dfektivspike
dfektivspike
1 year ago
I'd b e checking your earths and earth wires there will b a break I'd think
MichealH12
MichealH12
3 years ago
now here is the kicker!!! he went to college on it yesterday and there was nothing wrong with it, not one gremlin in the wiring. so I will monitor it and see what happens, but it is driving me nuts as I hate a mystery I need to know why and what caused it. anyway thanks for all the suggestions you guys have been brilliant.
iceng
iceng
Answer 3 years ago
Deep in sadness I must tell you this sorry fact... That oriental moped just does not like you :-(
cerberustugowar
cerberustugowar
3 years ago
it's hard to guess sometimes without seeing it in front of you or not having a wiring diagram to look at. But from what you are saying, the problem develops when you are moving or the engine revs up. If you put the unit on the center stand (the one that lifts the wheels off the ground) and rev it up so the wheel is spinning (be careful not to launch the scooter), do the gauges/indicators quit working? I'm just wondering if there is a wire that is shorting out that goes up to the gauges/lights, or if something is taking away the power when it revs up. Do the lights just cut out or do they slowly fade out?
MichealH12
MichealH12
Answer 3 years ago
i had it on the stand with the engine running the fuel gauge and indicators were working and then when I held the back brake on they just stop working, so I released the brake but they would not work not until I stopped the engine and turned the key off then restarted the engine.
iceng
iceng
Answer 3 years ago
Sounds like a processor gone haywire... Do a real reset, by removing the battery and pressing the hand brake..
MichealH12
MichealH12
Answer 3 years ago
thanks ill try that. I being doing a bit of research and was wondering if the voltage regulator/ rectifier regulator could have something to do with as it will not start with starter motor but it kicks of ok as well
cerberustugowar
cerberustugowar
Answer 3 years ago
does the starter work on the bench or when you bypass the solinoid. Just weird why the starter wouldn't work unless the battery or the wiring was bad.
cerberustugowar
cerberustugowar
Answer 3 years ago
You have checked the battery voltage and checked it again while it's running to make sure the unit is charging? While it's running, try putting the meter on AC volts and measure across the battery. I believe you are allowed upto 0.5VAC (they call it ripple voltage). If you have more than that, you might have a blown diode in your rectifier. .
iceng
iceng
Answer 3 years ago
I don't think so, a starter motor is a high battery current machine and in your case is switched by a heavy relay == contactor..
I would place a voltmeter across the two wires and see what happens when you start.. BTW I stick two needles into the vinyl wire an inch apart to measure...
If there is no voltage then it is the controller if it gets battery voltage then tryto see if the start motor gets battery voltage...
MichealH12
MichealH12
Answer 3 years ago
the lights are ok it is just the fuel gauge and indicators which die
rickharris
rickharris
3 years ago
A quick troll of the web suggests these vehicles have a LOT of electrical problems.
iceng
iceng
3 years ago
What it sounds like, meters work when on battery and IC engine not running but when ignition is firing the spark plug that battery cannot supply all..
Leading the inevitable conclusion that the engine is not replenishing (generating) electrical power..
Try when the meters are working turn on the headlight if it has one ?
MichealH12
MichealH12
Answer 3 years ago
thanks for the reply I charged the battery up and the headlight is on all the time
one of those Chinese things I guess. the fuel gauge and indicators work whilst engine is running, but when going down the road on it they cut out and no indicators.
iceng
iceng
Answer 3 years ago
Sorry you are in that area that would need me to use my hands tracing wires and a meter to unscramble...
BTW how long did you use it before this annoying thing started to happne ?
