755Views13Replies
Author Options:
555 frequency control another 555 controlling a servo motor.? Answered
Hey guys, I have another question. I'm in the planning stages of a project, It's basically supposed to be an astable 555 sending out a frequency that's supposed to control the mark space ratio of another 555 that's going to send a signal to a servo motor, causing it to oscillate back and forth.
Tl;dr, I want to make a servo wiggle around with two 555s. I have used the output of a 555 to modulate another one before, but I understand that using a 555 to control a servo is slightly different than just audio output.
So is there anything I should be aware of? Is there anything I can read or look at to point me in the right direction? Thanks.
EDIT: I just had an idea. What if I took the output of the first 555 (thus forth referred to as IC1) and used it to turn on a transistor, which connects a resistor in parallel to some part of the IC2 which decreases mark space and turns the servo.
https://www.instructables.com/id/Simple-Servo-Tester/
This one uses some pots to control rotation, if a resistor is connected in parallel using a transistor... something will happen. It moves.
steveastrouk
steveastrouk
Best Answer 8 years ago
Its going to take you three 555 timers, but here's the circuit for the hard bit.
You need to sort out your position signal, a 50Hz square wave reference and the scaling for the whole shebang, but....
The UN modulated pulse width = 1.1 x R x C.
You'll need the usual supply reservoir caps, and a 100nF across that.
Steve
steveastrouk
steveastrouk
Answer 8 years ago
Darn.
Bigger picture
mrmerino
mrmerino
Answer 8 years ago
Three timers? Yikes. Ok then, how would that work?
steveastrouk
steveastrouk
Answer 8 years ago
Read the circuit.....
1.) As shown,
2.) one to make a 50Hz 90% pulse train.
3.) One to provide your 0...3V modulation signal
Three.
fliboyzz
fliboyzz
8 years ago
Hi,
if you haven't found your solution yet. there is another post on here for a single servo walking robot that uses a different type of logic chip that seems to accomplish what you are looking for. search this site for "one motor walker", write-up by robomaniac
steveastrouk
steveastrouk
8 years ago
What kind of frequency do you want to wiggle it at ?
mrmerino
mrmerino
Answer 8 years ago
I want it to go back and forth at maybe one or 1.5 hertz, but I want to put a trimpot so I can fine-tune it. The first 555 is the easy bit, I'm not worried about that, it's how do I get the output of the first one to modulate the second one.
rickharris
rickharris
8 years ago
Understand how the servo works - I assume your talking an RC servo
If so assuming an analogue servo not digital:
They are operated by a pulse width modulation - changing the pulse width changes the position so it is the mark space ratio (off on ratio) you need to change not the frequency.
mrmerino
mrmerino
Answer 8 years ago
Right, yeah. I was somewhere else when I wrote that. But you understand what I want to do right? I want to use one 555 to alter the duty cycle of another. Can I do that?
mrmerino
mrmerino
Answer 8 years ago
Duty cycle. Shut up Mr. Merino, you have no idea what you're talking about. Let the nice man explain how to modulate the mark space.
rickharris
rickharris
Answer 8 years ago
To be honest I am not too sure - The M/S of the 555 is set by the Resistor and Capacitor connected to Pins 6 and 7 trig and threshold.
http://en.wikibooks.org/wiki/Practical_Electronics/Astables
shows a way to alter the M/S ratio by altering the resistor R1 R2 values. I can see you doing this with another 555
To be honest I would use a PIC micro - My choice would be from www.PICAXE.com
They interface direct to the servo and program in basic which is way easier than the A'duino and battling with C
mrmerino
mrmerino
Answer 8 years ago
I kind of need this to be as simple as possible, since I need this done in a few days. I also don't have quick access to a microcontroller, so I figured that 555s would be easy (if I clean my desk I could probably find 30 of them).
Again, thanks.
rickharris
rickharris
Answer 8 years ago
https://www.google.co.uk/search?num=10&hl=en&safe=off&site=imghp&tbm=isch&source=hp&biw=1760&bih=842&q=555+servo+driver&oq=555+servo+driver&gs_l=img.3..0i24.1781.5421.0.5548.16.9.0.7.7.0.128.879.8j1.9.0...0.0...1ac.1.ty-X3oMHPrk
may be useful
