70Views1Replies
Author Options:
555 timeout troubles? Answered
Evening all,
 This is most likely a very basic problem but for the life of me I can't find the solution. The project: auto folding wing mirrors (see below)
http://www.lexusownersclub.co.uk/forum/index.php?app=core&module=attach&section=attach&attach_id=6108
The problem: for some reason my alarm logic is the opposite way round, most likely due to the removal of my motion sensor due to it tripping my alarm when locked. Now I have modified the circuit shown in the PDF to remove TR2 and R4 so the I/P to the 555 is kept high by the 12v alarm signal. I have a pot between pin 2 and ground so I can adjust the pull down point as the alarm signal only drops to 9.7V and, obviously, the 555 needs logic high or low. So, having adjusted the pull down point, I find that the 5 second timeout, which worked when I first built the circuit as per the PDF, no longer switches the O/P off.
So so what am I doing wrong or is it just best to us a picaxe to do all of this as I code write up the code in half an hour or so.
thanks
Tags:555
iceng
iceng
5 years ago
Spent some time to resolve the circuit board to a schematic.
Perhaps tomorrow I will try to understand your problem.
It would not hurt if you verified the layout matches.
