275Views3Replies
6.3 Jack To 3.5 mini jack how?
Hello everyone, sorry for the trivial question..
Is possible to cut the wire and manually connect a 6.3 with a 3.5?
7 years ago
Just conect same tips
Biggest one is ground then its right and tip is left
7 years ago
Use a meter and do a continuity check to see what wire is connected to which part of the connector. Then you can match the wires of the connectors up.
7 years ago
Yes, its simple. You'll need to solder the connections though
