762Views8Replies
Author Options:
6V power supply Answered
HEY!
I recently took out a 6V DC motor from a CD player.
The problem is that I wanted it to power through the mains but have a 12V step  down transformer.
So, my question is that whether there is any way  I can  power it?  (except by using a 6v step down transformer)
Thank You
iceng
iceng
7 years ago
Just feed the 9v to pin_1 of the regulator.
Remember, the 9V battery cannot supply as much current.
A
steveastrouk
steveastrouk
7 years ago
First you'll have to rectify it to DC, and then add a regulator ideally.
mpilchfamily
mpilchfamily
Answer 7 years ago
+1 add a bridge rectifier so the 12V AC output of the transformer is converted to DC. Then add a couple of capacitors and an LM317 Voltage regulator with the right resistor to give you a 6V DC output.
ubdussamad
ubdussamad
Answer 7 years ago
Yes i totally agree to your answer i also use LM317 as my battery charger !
frollard
frollard
Answer 7 years ago
to be a little more efficient but a lot more work, if possible unwind half the secondary windings on the transformer.
iceng
iceng
Best Answer 7 years ago
Here is a build with your 12V XFMR.
A
steveastrouk
steveastrouk
7 years ago
If its got a split secondary, you might even be able to wire it for 6V
mrmerino
mrmerino
7 years ago
If your transformer has three output leads, you can step it down to six volts with only two diodes.
