139Views8Replies
Author Options:
74LS147N 10:4 priority encoder not working... Answered
Hi,
   This is a follow up of this question- https://www.instructables.com/answers/Logic-circuit-to-generate-and-convert-3-bits-paral/
I set all the 10 inputs of the encoder high and was expecting to see all the 4 outputs give a high(4 LEDs were connected to the outputs to see this happen).But that wasn't the case and just 2 of the LEDs glowed.I tried different configurations on the inputs but all the time it was either these two LEDs that glowed or none .Can this ic power 4 LEDs directly from its outputs? Could I have wrecked the ic?
Something a bit off the topic- What should I keep in mind while mixing TTL and CMOS logic gates?
I powered the ic with 5 volts.
Downunder35m
Downunder35m
Best Answer 5 years ago
It is a logic IC and simply checking the datasheet shows it can provide 8mA on the output - this is enough for a transistor to switch the LED but not to switch the LED directly.
You might have fried your IC.
Adarsh_tronix
Adarsh_tronix
Answer 5 years ago
Thought so! I am no expert in electronics and I found all those specifications on the datasheet very confusing.Gotta be more careful next time..thanx!
steveastrouk
steveastrouk
5 years ago
Oops. You can't drive leds directly!
Adarsh_tronix
Adarsh_tronix
Answer 5 years ago
But say I connect the outputs to the inputs of another gate,I wouldn't need transistors then,would I? Especially if the second ic is CMOS,I infer that it won't draw much current.
steveastrouk
steveastrouk
Answer 5 years ago
No problem !
The inputs of logic draw tiny currents.
The outputs can sink and source a "reasonable" current.
Look hard at all the small writing in a datasheet. Its there for a reason.....
Imagine I have a current sink/source capability of 1mA, and an input current of 10uA. I have what is called a "fanout" of 1000/10 or 100. So ONE output could drive up to 100 inputs.
If you want to test with LEDs, use the high efficiency red leds, which can run on 1mA, or make up a little tester with a ULN2803 driving your LEDs.
iceng
iceng
Answer 5 years ago
+1
Adarsh_tronix
Adarsh_tronix
Answer 5 years ago
Thank you! I will give greater importance to the data sheets.
Have heard the term 'fanout ' before..I think in PCB desiger softwares.Thank you for explaining what it means.
Yes,I will get a Darlington array as I don't want to burn out another ic.
Adarsh_tronix
Adarsh_tronix
Answer 5 years ago
Learned it the hard way :(
