2945Views-1Replies
Author Options:
8 bit Instruction set ? Answered
hello experts
I need some help
I want to make 8 bit instruction using folloing component so I made one simple example
8 bit instruction set
4 bit opcode + 2 bit source register +2 bit destination register+ 4 bit data
accumulator A
memory register R1
memory register R2
memory register R3
opcode         source       destination       data
0010               00               00                 xx
                 R1  01           A  01                xx
                 R2  10               XX                xx
                 R3  00               XX                xx
load data directly into R1
mov R1#data
0010         R1 01          00                  data
load data directly into R2
mov R2#data
0010         R2 10          00                  data
load data directly into R3
mov R3#data
0010         R3 11          00                  data
load data directly into A
mov A#data
0010            00         A  01                  data
mov the content of R1 into Accumulator
mov A, R1
0010         R1 01          01                  disable
mov the content of R2 into Accumulator
mov A, R2
0010         R2 10          01                  disable
mov the content of R3 into Accumulator
mov A, R3
0010         R3 11          01                 disable
don't use any register disable
0010               00               00                 xx      don't use register
vead
vead
Answer 6 years ago
hello
its just a paper exercise.
  • 4 bit alu
  • sel1 source register for alu
  • sel2 source register for alu
  • destination register for alu
    program memory
  • Program memory address bus -
  • Program memory data bus -
  • Program memory read enable;
  • Ram memory
  • Register memory address bus -
  • Register memory data bus -
  • Register memory read enable;
  • Register memory write enable
    accumulator register
  • 0
    vead
    vead
    Answer 6 years ago
    data transfer instruction from A resistor to R1 resistor
    Instruction set
    c c c c c c a b b b b r r r r r data
    --opcode--- a --bit-- register data
    6 bit op code - specify operation code such as add,mov ,subtract
    A (choose memory registers or accumulator )
    1 indicate A and 0 indicate memory register
    4 bit data
    4 bit source - specify the source
    5 bit destination -specify the destination
    mov A #data
    load data with A register
    100010 1 1111 11100 data
    mov R1 #data
    load data with R1 resistor
    100010 0 1111 11100 data
