144Views7Replies
85 LEDs taking 20ma each individually wired with a resistor, what ma power supply is needed?
For 85 LEDs each taking 20ma wired individually with a resistor off of a single 9v power supply I would need at least a 1700 ma power adapter correct??...I would probably go with a 2000ma one though just to be safe.?
Best Answer 9 years ago
85 * 20 = 1700. Yes. 1.7 amps. You shouldn't need to go much above that, but it generally won't do any harm if you do.
Answer 9 years ago
+1
9 years ago
While orksecurity is right, the solution to wire each LED individually is just a waste of energy.
What kind of LEDs do you use? (The options you have depend on the forward voltage which is different for different LED colours)
Have a look here: http://led.linear1.org/led.wiz
E.g. with red LEDs (Uf=2.0V) you can go with only 440mA totally consumed current!
Answer 9 years ago
Yea I know its kinda a waste but with varying colors meaning varying voltage I just wanted to be safe and wired them each with their own aproprite resistor. Thanks though for confirming my question.
Answer 9 years ago
Good point.
Answer 9 years ago
+1
You want as many series leds as you can fit on your power supply. If you have 9v supply and 2v leds, you need 4 in series plus a resistor to burn off the last volt to make 9.
Answer 9 years ago
+2
And if you find 85 red LED with 1.7 Vf then you can run on 340 ma
