275Views6Replies
Author Options:
93 ford ranger 4.0 v6 ac compressor into engine driven aux air ? Answered
for my air ride system
Tags:auto
jjhaney
jjhaney
Answer 9 years ago
the lines air ran everything is there , i just dont want to run electric all the time .just need to know how to run the a/c compressor to 200psi continuous without blowing it up
steveastrouk
steveastrouk
Answer 9 years ago
Presumably you AREN'T running continuously, or you have a huge air leak. What is the ACTUAL gas consumption of your air-ride ?
jjhaney
jjhaney
Answer 9 years ago
by continuous i mean my tank will have a pressure switch 165 on 200 off . it will stay in that range continuously. in not sure of the consumption but it takes 150 psi to get my front off the ground
steveastrouk
steveastrouk
Answer 9 years ago
I'd suggest it takes very little actual volume to lift you up. If you're on electric pumps, how often is your current pump cycling ? Electric pumps are WAY easier than an AC pump in this application, because they give pretty well oil free air.
AC pumps need careful feeding and attention - they have to work properly oiled, and are not designed to keep that oil vapour out of their outlet lines.
Steve
Re-design
Re-design
9 years ago
You could make it work but you'd have to heavily modify the a/c compressor, install some valves and plumbing etc.
A better idea would be to install a separate electrical compressor that needs no modification.  You'll still have to install valves, gauges and plumbing etc.
Unless I guessed wrong on what your question really meant and in that case just ignore this post.
