150Views11Replies
9V battery heating up instead of the heating element
i am trying to make a heater out of nichrome wire. i have got a heating element (100 W) made specifically for 9V . but when i connected it to the battery, after few seconds of heating the element my battery heated up and i had to remove the connections.
what am i doing wrong
P.S.
the heating element is connected to a stainless steel glass for heating 250-300 ml water to about 100 degree celcius.
Please help
4 years ago
Is stainless steel glass anything like transparent aluminum ?
Answer 4 years ago
Glass, like a cup, not the substance...
Answer 4 years ago
Thanks, this language offers so much for humorous interpretation.
You do know where transparent aluminum was invented ?
Answer 4 years ago
Hmmm... Interesting!
I'd like to have some of that... (Though I see that it's only 80% transparent, so I think I'll stick to plexigkass :)
Answer 4 years ago
Star Trek IV movie where Kirk and group travel back in time to retrieve a mother whale to save the future and Scotty teaches a SF plastic formulator how to make a transparent aluminum for a sea water tank to transport wales in a stolen Klingon ship..
https://en.wikipedia.org/wiki/Star_Trek_IV:_The_Vo...
4 years ago
You need a bigger battery!
A 9V battery can't supply enough power (amps, aka current). You need a current source that can supply at least 12 amps.
4 years ago
Your battery has more internal resistance than the nichrome wire, you need a bigger battery! No way a small 9V battery can deliver that much current (11A), they are often rated 500mA maximum, and <100mA recommended. You would need to connect over 20 batteries in parallel for that.
Try alkaline lantern batteries, large lead acid, or NiCad drill battery instead.
Answer 4 years ago
+1
4 years ago
No way a 9V rectangular battery can supply that much power.
Ye cannae change the laws of physics
4 years ago
Your 9V battery is not a magical perfect power supply (no real world power supply is). The battery has an inner resistance. It works like a real resistor . Any current flowing through your heater will also flow through the battery - and therefore this inner resistor. So when your heater heats up, this inner resistor heats up too.
What kind of battery do you use? Did you do the math about how much energy is needed for the heating / how much energy is in the battery?
4 years ago
Your drawing FAR too much current from the battery. A 9 volt battery - square type - is only capable of milli amps.
Your project is never going to happen.
