334Views2Replies
Author Options:
9v to 3v "easy button" hack. Answered
Hello!
Im working on a Staples Button Hack! but.....
Problem that I have is that I feel like it is a Waste to scrap the original "that was easy" message. And the problem that comes along with this would be that I have to use a 9v battery to power the new circuit and the original button circuit uses a 3v battery.
I'm not great with Ohms law but I do relize that I need a resistor but... i do not know if that will put in too much current into the original circuit?Would anyone know how I can calculate this? And does the amount of current even matter?
-Thanks!
Noobiefied
aelias36
aelias36
Best Answer 9 years ago
Try reading this:
https://www.instructables.com/answers/How-much-resistance/
LargeMouthBass
LargeMouthBass
9 years ago
I'd use a small voltage regulator. There are regulators that have only 3 terminals: input, ground, and output. The only other parts they require to operate properly are a couple capacitors for the input and output, which the datasheet for the regulator will suggest.
The regulator will produce a constant 3V output, regardless of the load. Make sure you select one that can handle the current your circuit needs, which is most likely very low.
All the part required should be less than a couple dollars total from a source like DigiKey.
