1277Views9Replies
Author Options:
A device to measure the intensity of light should I do. Help Please? Answered
Actually thisis ahomework.Wouldyou help me.Ido not know how.What materialsshould I use.I wonder how can I dol. In fact, my homework to make an the sensor, example of rain sensor. That is something like I will a new sensor produced. I'm sorry I'm trying to write Google translate
thanks.....
Tags:sensors
Jack A Lopez
Jack A Lopez
9 years ago
The short-circuit-current of a solar cell should be roughly proportional to the intensity of light reaching the cell.
A simple model to explain how this works is to assume each single photon hitting the cell,  contributes one electron to the short circuit current.  Light intensity is (photons/time/area)*(area of cell) ~ (electrons/time) = current
As an example:  a silicon solar cell, with an area of about 1cm^2, illuminated with dim indoor lighting, produces a short-circuit-current of about 20 microamperes of direct current (DC).  The picture is from:
https://www.instructables.com/id/How-to-Listen-to-Light/#step5
20 microamperes (μA) is a  small amount of electric current, but easy enough for a typical, cheap, multimeter to measure.
In bright sunlight, this same setup would produce much more current.   I am guessing somewhere between 10 and 100 times as much current; i.e somewhere between 200 and 2000 μA, or 0.2 to 2.0 mA.
Anyway, the game here is that a solar cell can be used as a light sensor, where short-circuit-current is proportional to light intensity.
See also:
http://en.wikipedia.org/wiki/Theory_of_solar_cells
ottoman-snr
ottoman-snr
Answer 9 years ago
thanks jack .SUPER.
With this circuit so I can measure the intensity of light?
Based on the intensity of the sunlight to light the LCD screen as a percentage, Can I write. for example, the PIC circuit
Jack A Lopez
Jack A Lopez
Answer 9 years ago
I'm not sure what you mean by "PIC circuit".
Do you mean how to use this signal as an input to a microprocessor, e.g. a PIC(r) microprocessor?
Or do you mean PIC, like picture, just a circuit diagram?
ottoman-snr
ottoman-snr
Answer 9 years ago
Programmable Interface Controller talking to.Microcip Product. Can I print using the LCD to the temperature or arduino uno.
thanks..
Jack A Lopez
Jack A Lopez
Answer 9 years ago
The analog inputs on a PIC(r) or Arduino(r) want a voltage signal , typically in the range from 0-5 volts.
The output from a shorted solar cell is a current signal, so you will need a circuit to convert current into voltage.  The usual way to do this is with an op-amp wired as a current-to-voltage converter (also called transconductance amplifier).  A diagram of such an amplifier circuit is attached.
https://www.instructables.com/file/FRA9FQ9GTLRHLEE/
For this circuit, Vout = I*R, and you choose R to give the desired gain.  For example R=100 KΩ gives 1 volt for every 10 μA of photo-current.  If you picked R=1K, then you would 1 mA = 1000 μA of photocurrent to get 1 volt of Vout.
The capacitor C, is placed there to limit the response to low-frequency signals.  I am guessing you just want to measure slowly changing light level.  So a good choice for C, would be that C which gives R*C= 1s (time).
The following Google image search will show you similar circuits:
http://www.google.com/search?hl=en&tbm=isch&q=photodiode+amplifier+circuit
ottoman-snr
ottoman-snr
Answer 9 years ago
Oh great, man. Thank you very much.
rickharris
rickharris
9 years ago
small wood block with 2 drawing pins on it about 2 mm apart.
A wire to each drawing pin. Connect as diagram with an NPN transistor as a switch. The LED lights when rain bridges the drawing pins.
ottoman-snr
ottoman-snr
Answer 9 years ago
thanks rick.....
kelseymh
kelseymh
9 years ago
Did you not read the responses to your previous request?
