113Views20Replies
Author Options:
A hot box full of Satan!!! Answered
I'm already preparing for Halloween. One of the props I would like to build is a box to hold "Satan." I'm not yet sure what I want it to look like (rock? metal?)... but I do know that I want it to be warm to the touch. Not HOT... nothing that would actually harm anyone... but obviously - and devilishly - warm. My first best thought is to take something like an old-school metal lunchbox, create false walls on the top and bottom, and then put SOMETHING in the in-between spot. But what? Chemical hand warmers? Something battery-operated. Your ideas are welcomed. And if a little bit of smoke could come out, all the better. Please shout if you need any clarification!!! Thanks!!!
gravityisweak
gravityisweak
2 years ago
How about just using incandescent light bulbs? If you place them close enough to your walls you can use a dimmer to adjust the heat until you are comfortable with the temperature. With any battery operated device, I think having it be warm is going to be a challenge since heating uses a lot of energy. Depending on how long you need it to last for you could also build false walls and fill them with those microwavable and reusable body warmers. Toss in the microwave for 2 minutes and stick it inside. Of course you have the challenge of it getting slowly cooler over time but you can always have more warmers on backup.
Purple Chez
Purple Chez
3 years ago
I am loving all of the great info you guys are sharing. I am most drawn to the plan of attaching resistors to aluminum. Any additional referrals to this topic would be most welcome. Happy Easter y'all....
bravoechonovember1
bravoechonovember1
3 years ago
look up bird bath heaters. they might work for this type of thing
randofo
randofo
3 years ago
You might want to investigate a Peltier junction:
https://www.adafruit.com/product/1331
One side heats up when electricity is applied. The other side cools down. If you attach the warm side to a metal sheet, it will heat up.
If you are worried about overheating, you can use a temperature sensor to trigger an Arduino to turn it off when it gets to a certain temperature.
Yonatan24
Yonatan24
Reply 3 years ago
I thought of using a peltier element but if they are ~30% efficient at cooling, their intended use, it means you're just wasting 30% of the power used if you only want to use them for heating.Which is why I suggested using resistors.
How about something like this?: https://www.ebay.com/itm/PTC-Aluminum-Ceramic-Heat... I've never seen these before but they might be worth a try.
Toga_Dan
Toga_Dan
Reply 3 years ago
typically when an electric device is inefficient, it means the wasted power turns into heat..
Yonatan24
Yonatan24
Reply 3 years ago
Yes, but if you want to use a peltier element for heating, then the cooling is the "wasted" power.
randofo
randofo
Reply 3 years ago
It might be a little less efficient, but it uses less current. You would need some really big resistors and would need to be feeding it a lot of current to get it to heat up a large surface.
They would be better off removing the resistor from the equation and using nichrome wire. There would be a bit of math involved to get the legnth of wire and temperature just right, but that would essentially accomplish the same as a resistor and use less current.
That said, Peltier junctions are still the easiest solution and will solve the problem at hand.
Purple Chez
Purple Chez
Reply 3 years ago
Neat!!!!! Thanks!!!
Toga_Dan
Toga_Dan
3 years ago
melted parafin is reputed to hold a lot of heat. the phase change between liquid and solid releases heat for some time.
Jack A Lopez
Jack A Lopez
3 years ago
I forgot to link to the Wikipedia page for, "Phase-change material",
https://en.wikipedia.org/wiki/Phase-change_materia...
Also I should mention, one of the cheapest, easiest to find, PCMs, with a melting point that is, "warm", around 50C or so, is paraffin wax.
https://en.wikipedia.org/wiki/Paraffin_wax
The quick summary of this, is that a large mass of wax, like a few kilograms of it, will take a long time to melt, and also take a long time to re-solidify.
By the way, the heat required for the phase change, around 200 kJ/kg ( or 0.2 MJ/kg), is comparable to the specific energy of batteries, i.e. energy stored per unit mass, if I can believe what I read in that table, in the Wiki article for, "Energy density", here:
https://en.wikipedia.org/wiki/Energy_density#Energ...
Regarding safety, I think the main thing is to keep liquid paraffin away from open flame. It is definitely flammable. It is the same stuff they make candles out of.
Jack A Lopez
Jack A Lopez
3 years ago
By the way, did you know that the Ancient Hebrews used to carry their god around in a box?
https://en.wikipedia.org/wiki/Ark_of_the_Covenant
Anyway, it was a truly freaky artifact. It spontaneously emitted heat, and smoke, and occasionally it would strike people dead, like, seemingly just to prove it could.
https://en.wikipedia.org/wiki/Uzzah
Anyway, the Ark was lost for thousands of years, but thankfully, Indiana Jones found that old thing before the Nazis did (they were both looking for it), and now it is safely stored in a government warehouse, somewhere on a military reservation in Nevada, I think, which is part of the Former United States (FUS).
Purple Chez
Purple Chez
Reply 3 years ago
Great idea, but I don’t want people struck dead for touching it!!!!
Jack A Lopez
Jack A Lopez
Reply 3 years ago
You make a good point about safety. I mean, whatever you come up with is going to have to be safe enough to withstand being handled, or mishandled, by children, or drunk partygoers, or whoever is coming to your Halloween party.
There was some some old quote about about fire being like government, i.e. a dangerous servant and a fearful master.
Yonatan24
Yonatan24
3 years ago
Ok, so smaller than I thought.
My first thought was to pour molten aluminum inside somehow, and then to glue 5W resistors to the aluminum once it cools down with thermal adhesive.
How long do you want it to stay hot?
Sound interesting!
Purple Chez
Purple Chez
Reply 3 years ago
Several hours. What if the box itself is aluminum... in the style of an old school lunch box?
Yonatan24
Yonatan24
Reply 3 years ago
The maybe a hand warmers would be a better option, allowing for them to be replaced once they stop heating.
To make it look like rock I thought pouring epoxy resin, and sprinkling sand over it, but I kind of need more information...
Jack A Lopez
Jack A Lopez
3 years ago
I humbly suggest looking at the Wikipedia article for, "Hand warmer",
https://en.wikipedia.org/wiki/Hand_warmer
which mentions, iron-air, hydrocarbon-air, and phase change material, type hand warmers.
The Wiki article for, "Smouldering" combustion,
https://en.wikipedia.org/wiki/Smouldering
I also suggest looking at the TVTropes.org articles for, "Artifact of Doom", "Soul Jar", and "Evil is not a Toy"
http://tvtropes.org/pmwiki/pmwiki.php/Main/Artifac...
http://tvtropes.org/pmwiki/pmwiki.php/Main/SoulJar
http://tvtropes.org/pmwiki/pmwiki.php/PlayingWith/...
Also, please consider the idea of doing something else, anything else, for your planned Halloween prop, costume, whatever, while there is maybe still time to save your soul.
Purple Chez
Purple Chez
Reply 3 years ago
Thanks!!!!
As for my soul... it’s actually going to be linked to cartoony demons, like the Red Guy from Cow and Chicken, and Jon Lovitz’s devil. It’s not really a devotional item
