97Views9Replies
Author Options:
AMPLIFIER Answered
Hi
Im new to the site and it is awesome
Can someone tell me where in a speaker /radio/walkman is the amplifier as I really want to make one for a project
Can you tell me how can I salvage an amp to make an Altoids amp powered by a 9V
Thanks a lot
thegeeke
thegeeke
9 years ago
Not all speakers/radios/walkmans have amps... some are non-powered which means that they don't have a built in amps and need an external amp. Please post the model number for the device you are looking for. :)
B_qwerty
B_qwerty
Reply 9 years ago
OK so speakers walkmans dont have amps
But pls tell me where can I salvage one
I dont want to buy one from radioshack or other shops
I also cant make one, since I cant understand circuit diagrams very well
But I am willing to learn
So pls give me info on how to make a simpe amp or salvage one
thegeeke
thegeeke
Reply 9 years ago
Making one would be pretty hard if you don't want to go buy components from a store... but if you have some old computer speakers laying around, they usually have some decent amps in there, or basically any powered speaker would have one.
Maybe could you post a link to the project you are trying to build? That might help me give you more suggestions. :)
B_qwerty
B_qwerty
Reply 9 years ago
Thanks for your time thegeeke
Well can you tell me how to take the amp out of my speakers since I have some but I hope I can power them with a 9volt battery
https://www.instructables.com/id/Make-a-Simple-Audio-Amplifier/
I want to find an amp like this without getting mixed up with the boards capacitors etc
As I said before I'm trying to make a tinny amp or an altoids amp for a project involving conversion of electricity into sound
https://www.instructables.com/id/Altoids-Amp/
This is want I want to make but the reviews aren't too good. Also there aren't many pics.
P.S. Is it possible to get an amp from a telephone
thegeeke
thegeeke
Reply 9 years ago
Well, yes, there is a very small amp in the walkman he was using, but it's just meant for powering headphones, not speakers. (I assume you are trying to power speakers?)
Same thing with a telephone, it's basically just a amp for a small speaker or headphone. It will not power any speakers that you can hear.
The easiest way that I can think of to find an amp would be to take apart a small powered speaker and rob the amp from that. Then just connect an input the the input wires for that amp, and then connect whatever you are trying to power to the output wires. You should be able to get a project enclosure for it if it doesn't fit into a Altoids box. (Depending on the size of the amp you are stealing it probably will not fit into a Altoids box.)
Good luck!
B_qwerty
B_qwerty
Reply 9 years ago
Thanks
I found an instructable that is just like your description
when I make it I will post a pic here
thegeeke
thegeeke
Reply 9 years ago
Good luck! Sounds like a fun project!!! :)
thegeeke
thegeeke
Reply 9 years ago
Oh... forgot to tell you about powering with a 9 volt. Most powered speakers are powered via DC, so there is either a AC-DC adapter that plugs into the wall, or there is a AC-DC conversion circuit in the speaker. Just plug the 9 volt past the conversion, and if you're lucky it should actually power it. Worst case in senerio, you don't have full power. In that case you could try hooking two 9 volts in series. :)
aherman5
aherman5
9 years ago
Buy this kit and use you own speaker...
http://www.etsy.com/listing/80422688/new-diy-kit-altoids-pocket-guitar
