This is like asking what is your favourite colour. Your going to get a lot of answers.
There is also a lot of information anyone would need to be able to give a realistic answer, what you expect it to do, budget , time scale skill level of builder. ultimate reason (a toy or hobby or something more commercial.)
I guess your thinking about an autonomous ROV - For a start personally, I would go with the Picaxe system http://www.rev-ed.co.uk/picaxe/
Relatively cheap, fairly powerful and fast to develop with masses of expert support in their forum. Once you have a handle on the real requirements and scope of the project you will be in a better position to look at other options.
basically the project is this.. 'Design and fabrication of RC Submarine'
• To acquire basic knowledge in the field of hydrodynamics, fluid mechanics and Submarine design. • To design a new model of RC Submarine by using proper standards and procedures. • After the completion of conceptual design, the iteration process will be commenced to obtain the best suited and efficient design of RC Submarine. • A parallel work in the field of electronics and Radio transmission will be initiated with the design process because if the design is finalized then without wasting the time. • After finalizing the design there will be detailed performance analysis. • The material and structural selection will be finalized as per requirements. • Fabrication is an essential part of the project which will be performed after the completion of every aspect of design and performance analysis. • Implementation of the circuitry and control block will be implemented according to the design.
Best Answer 9 years ago
Answer 9 years ago
+1 to that.
(They're waterproof too #;¬)
9 years ago
9 years ago
it is radio control...
9 years ago
Do you mean RC (radio and/or remote controlled), or do you mean robotic?
If RC, you may not need a microcontroller at all (though you will need to think about how you're going to get a control signal through water).
9 years ago
As it is said, "How long is a piece of string ? "
Specify all the other systems, then decide what you need.
Steve
