697Views8Replies
Author Options:
About audio amplifier boards? Answered
I've brought TDA2030 amp board for stereo system(pictures attached). I can't identify audio input terminals. Experts please help me!
iceng
Best Answer 3 years ago
Red=positive 12volts DC and Black=negative ground supply power for the amplifier.
Yellow and Black pair each are a pair of speaker wires.
Just before the negative of the 2.2 uF negative there appears to be an input where you could solder a Green-signal wire with a gray wire for ground times two.
A better straifght cook down at the pcb would help trace the inputs.
chrisjlioneliceng
Answer 3 years ago
Thanks. That really helps. pin 1 followed by caps + terminal is signal input.
Downunder35m
3 years ago
Ask where you bought it, if they can't provide the info hand the junk back and get a refund.
chrisjlionelDownunder35m
Answer 3 years ago
That's the problem. No refund for goods imported from china. Clearly stated in the bill.
