7393Views13Replies
Author Options:
Acrylic Lichtenberg figure? Answered
I have only see a how to do it on wood. So is it possible to create a lichtenberg figure in plastic?
Ofc I have done my research on the topic but I'm not sure if a microwave transformer can do the trick. Or if a plain piece of acrylic is conductive enough to let the electron flow through.
Thank you for your reply
Kiteman
Kiteman
Best Answer 4 years ago
Google for "acrylic lightning". You'll need a lot more than a microwave transformer, they need hundreds of thousands of volts, dumped from very large capacitor banks.
Downunder35m
Downunder35m
4 years ago
You are confusing me!
What is the relation between making a figure from acrylic and a microwave transformer??
If you make such big jumps inside you mind it might be helpful to add a few more step in your written form so others cn follow.
BertHickman
BertHickman
Answer 3 years ago
There is no relationship. The processes are completely different. Microwave oven transformers (or other high-voltage sources) can be used to create carbonized surface Lichtenberg figures on wood or wood products. The surface is made partially-conductive by applying a water solution, often mixed with a little baking soda to make it more electrically conductive. When HV is applied, fractal-like conductive carbonized surface paths are created over a period of seconds or minutes as the wood breaks down under high voltage stress, with the pattern growing along the borders of the drying water solution. Although the process is dangerous (due to the high voltages), careful hobbyists can easily do this at home.
In the case of acrylic Lichtenberg figures, electrons are actually injected deep INSIDE the acrylic by a high-energy particle accelerator. We use electron beam energies between 2 and 5 million electron volts (MeV). As electrons accumulate inside the acrylic, the potential of the internal charge region climbs. Because acrylic is an excellent electrical insulator, the excess electrons become temporarily trapped inside. When fully charged, the potential of the charged region inside the acrylic can easily exceed 2.5 million volts. Poking the surface of the acrylic with a sharp metal point allows the internal charge to suddenly escape in a brilliant flash and bang. The intense heat and pressure along the discharge paths create millions of tubes and fractures, leaving behind a permanent "fossil" Lichtenberg figure. The complete Lichtenberg figure is created in less than 1 millionth of a second.
iceng
iceng
4 years ago
Hopefully your research is a bit improved...
steveastrouk
steveastrouk
Answer 4 years ago
LINK ! That's beautiful.
steveastrouk
steveastrouk
Answer 4 years ago
I DID, I just ordered a piece off them ! Watch the video of the creation process. Awe-inspiring.
iceng
iceng
Answer 4 years ago
When you get your art piece I hope you post a picture...
steveastrouk
steveastrouk
Answer 4 years ago
Its just arrived, its very pretty. I need to make a light source.
Shizen
Shizen
Answer 4 years ago
*facepalm*
I picked Kiteman's answer as best one already...
Shizen
Shizen
Answer 4 years ago
Ofc I know that, I'm asking if I can MAKE one myself
steveastrouk
steveastrouk
Answer 4 years ago
Read the article in the link Iceng has posted.
No.
iceng
iceng
Answer 4 years ago
No
