412Views2Replies
Adding a resistor to a battery pack?
I am new to LED's and havent messed with electronics since the 80s, so excuse my ignorance and all of the questions. My question is, if I have a 3 AAA battery holder, each battery is 1.5 volts, for a total of 4.5 volts. If I have a 2 volt LED and use only 2 batteries (3 volts), can I solder the resistor into the 3rd battery compartment to lower the voltage, or must I use a dummy battery and put the resistor between the battery pack and the LED?
Thanks!
Best Answer 11 years ago
Solder it where you like, no problem, unless its going to dissipate a lot of power.
Steve
11 years ago
Connect your LEDs across compartments 1 & 2 with the resistor.
L
