112Views8Replies
Author Options:
Adding an indicator led to a multimeter when it is on? Answered
I would like to add an indicator led because I keep leaving it on and draining the power.
iceng
iceng
Best Answer 5 years ago
Better then a steady LED blink it once every ten sec less power and catch your eye.
iceng
iceng
Answer 5 years ago
Here is a circuit to work with :-)
steveastrouk
steveastrouk
Answer 5 years ago
I thought that chip was obsolete ! Nice circuit.
Wired_Mist
Wired_Mist
5 years ago
Why not make an AC adapter?
Many DC-Barrel jacks will allow you to draw power from your battery when not plugged in. This would let you stay mobile around your shop.
Then when you are at your bench plug it into an appropriate DC power adapter.
-max-
-max-
5 years ago
What multimeter? It might be easy to hack on a LED to the range switch, so it comes on when anything but the off position is selected. You may even be able to find the product manual for it and a auto shut off option.
hkerr
hkerr
Answer 5 years ago
It has a button to turn it on
steveastrouk
steveastrouk
5 years ago
Not difficult to do, but try and find a high efficiency red LED, one that will run happily, and bright enough on <1mA - or your LED will flatten your battery faster than just leaving it on.
