1891Views10Replies
Author Options:
Adding voltage and current from different devices? Answered
How do you add the output from devices which are generating distinct voltage and currents? Two windmills for example or a windmill and a solar cell.
Udon
Udon
11 years ago
Yeah that's a good question. I also don't know. Maybe we should try it out for ourselves - treat the whole power supply like a battery, output and common, in series with another one. I wanted to try it with more than one jewel thief. Might work. Um. Or not...
mkcimini
mkcimini
Answer 11 years ago
Hoping that a power supply person might know. The knowledge should be out there somewhere.
lemonie
lemonie
Answer 11 years ago
You can isolate the sources from each other with diodes, but what are you using and what do they / will they feed-into?
L
mkcimini
mkcimini
Answer 11 years ago
Feeding a battery. But wondering what is the best way to add devices that are of different V and I.
lemonie
lemonie
Answer 11 years ago
You might need some kind of voltage multiplier to get up to the 14-17V, but you could arrange like this L
mkcimini
mkcimini
Answer 11 years ago
So you are suggesting a voltage regulator to get each source to a reference voltage and then connect them to the battery?
lemonie
lemonie
Answer 11 years ago
I guess that is what I'm suggesting, but I don't know what you've actually got to build this with at the moment. L
robotguy4
robotguy4
11 years ago
Hmmmm... Hold on... I may know a simple formula for this one...
-=ACHTUNG!=-
I'm a theoretical guy, so I suggest you receive a confirmation about this before you calculate and use it. You would need to use a diode for the solar panels, I think.
First, learn about series and parallel circuits.
Adding voltages in series:
v1+v2=vtotal
Adding voltages in parallels:
1/(1/v1+1/v2)=vtotal
I forget how you determine the current. It is very likely that you could treat these as regular power sources (batteries) with variable voltages.
mkcimini
mkcimini
Answer 11 years ago
But to charge a battery you want to keep the voltage around 14 to 17 volts. So is it better to put them into series or parallel and then convert to required voltage? For arguments sake lets say s small field of wind turbines each having different motors, charging a battery bank.
robotguy4
robotguy4
Answer 11 years ago
Oh... Wait... You want to CHARGE BATTERIES? I thought you just wanted to run something off them. Oh, yeah. Thats different from what I was saying. Disregard what I was saying.
