Adjustable Teeth comb
My innovative idea is regarding an adjustable teeth comb. There are Many type of combs available in the market but problem is that one's cannot use all these types of combs at a time. There are wide teeth comb,semiwide teeth,and fine teeth combs are available in the market.To prevent the hair loss it is very necessary to find right teeth comb. The solution is here in this Idea. Discription: As per sketch there is a wide teeth comb and each teeth will have 1 cm.space with each other teeth. There will be an another comb which will slide on the wide teeth comb. The sliding comb will work in this way that the User can set the teeth of comb as per his desire or as per his hair style requirement. After setting the teeth the slider comb will be locked.In another words it will work like "Sliding Cutter mechanism". In this way this product will work. Salient features: (1) No need of buying different teeth comb as one's can set the space of teeth of this comb (0.5 mm to10mm) and this adjustable comb will work to prevent hair damage as it will not intangled with hair. (2) low cost (3) easy to use (4) light weight (5) easy to clean (6) Prevent Hairloss or suitable for all kinds of hair style. (7) Both Female and Male can use it. (8) very useful to detangle hair due to adjustable teeth for curly hair.
