Alter a small solar water pump to run off battery ?
I bought a small smaller pump off amazon (1.2 Watt Solar Power Water Pump Garden Fountain - for fountains, waterfalls and water displays) the solar panel is crappy and very finicky ( cheep) and does not hold a charge .. I was hoping to alter the power source to another solar panel or add another panel that comes off those solar lights that holds a change .. Alternatively modify to use a battery source with a on off switch ..
I know I don't need to alter the pump just want a continuous power supply. Current Specs that cam with the unit : solar power supply 7 v 1.2 w ( if that !) power of pump 7v , 1.1 w/ max lift 100 cm / size of solar panel ( 100mm x 100m x 25 mm) / max outflow quality of pump 180lh max water height 30 60 cm ( if that!)
4 years ago
Did you check out my Instructable on Simple Solar Circuits:
https://www.instructables.com/id/Simple-Solar-Circu...
To run all night you would need about a 2 aH battery and about 400 ma output from your solar cells to run 24 hours a day.
That solar panel is 170 mA so you would need about 3 of them in parallel with a diode on each to prevent the solar cells from draining the battery or the power from the other solar cells.
Answer 4 years ago
+1
4 years ago
Solar Panels aren't supposed to hold charge.
4 years ago
this is the spec of the connector and s video of the panel and pump
