386Views3Replies
Author Options:
Alternative ways to create a one-way mirror? Answered
Hello,
I'm creating a video installation with rear-projection. I want the viewer to see his reflection and the projection so I was thinking of half-silvering Mylar or acetate to create a screen. I also thought of mixing aluminum powder with a clear medium and painting it on however, no luck finding that in Canada.
My only issue with silvering the screen is that it is so large (10x5ft) that I don't know how to go about heating it up when I pour the solution over it.
Looking for suggestions for other materials as well as solutions to these issues. Thanks!
petercd
3 years ago
You could try making your own aluminum powder using tinfoil in a ball mill.
Downunder35mpetercd
Answer 3 years ago
Good for fireworks, bad for reflective properties.
Downunder35m
3 years ago
For big areas you can also use tintin foil for windows, it is available as a mirror foil as well.
rickharris
3 years ago
a simple sheet of glass will give a good reflection and allow back projection - peppers ghost-
For semi silvering try removing the paint on the back of a mirror with pain remover - then score the silver with a sharp blade at regular intervals - this produces a sort of half silvered effect.
