998Views8Replies
Author Options:
Amp problems: Audio output cuts out on any bass.? Answered
I have a Sonic Impact T-Amp Gen 2. When running, the audio output suddenly cuts out on the bass of a song for half a second or so, and starts again. The blue LED light stay on however. There seems to be no connection between the times it cuts out, except for it usually runs for a while, at 50% < 100% of the volume. Can anyone help? Thanks.
lemonie
lemonie
Best Answer 11 years ago
What is it connected to - sounds like it might be cutting out to protect itself from overload? L
finnlay
finnlay
Answer 11 years ago
It's a 12V 7aH battery, hooked up to the amp. It then provides 2x15W channels at 4Ohms, to one speaker in each channel, that are 4-8Ohm. It never used to do this when played full volume. I have however got new louder speakers. Do you think it could be this? Thanks
finnlay
finnlay
Answer 11 years ago
I tried it with the old speakers I never had a problem with, and they still keep cutting out. Any more theories? Thansk
lemonie
lemonie
Answer 11 years ago
What I could find doesn't suggest anything wrong as such, but if this started after you got new louder speakers, I'd suggest these are it. I.e. it is being overloaded at high volume and cutting out before it goes into smoke-machine mode...
L
finnlay
finnlay
Answer 11 years ago
Yeah i must be that. Thanks.
steveastrouk
steveastrouk
Answer 11 years ago
Check the voltage on your battery as it goes into peak load
NachoMahma
NachoMahma
11 years ago
. I think lemonie is on the right track. Compare the amps rated output impedance with that of your speaker system. If you have more than one set of speakers hooked up, get rid of the extras.
