244Views4Replies
Author Options:
Animatronic hand help! Is this the right tubing? Answered
The instructables member Tannatraad  made an instructable on how to make an animatronic hand. (https://www.instructables.com/id/Simple-Animatronics-robotic-hand/#step1) and it is made using the black wire encasing tubing found in cars. I bought some, but mine has a slit running down the whole side. The picture shows exactly what kind of tubing it is (ignore the clear tubing.) Is there a simple fix, or do i have to go out and buy the right kind of tubing, if what i have won't work.
davidhodson94
davidhodson94
Best Answer 8 years ago
You can get your wire loom from http://www.cabletiesandmore.com/wireloom.php.
Really they can help you for making nice your car. So that you can check this link and get a important decision for you. Thanks.
rickharris
rickharris
9 years ago
Either glue the tube together or put heat shrink tubing over the outside and shrink on.
frollard
frollard
9 years ago
probably need to get the solid tubing...
iceng
iceng
9 years ago
Themajor13 said "Try an automotive store. I work for Napa and we have a bunch of that stuff for wiring cars. It's called wire loom. Make sure you don't get the split loom because it has a slit down the center."
I have the split version for easy insertion of wire bundles after the fact into
the protective shroud and didn't even know that they were available as
un-split tubing.
So I read the 244 comments on the instructable you referred.
A
