1402Views16Replies
Author Options:
Any substitute for Smooth-Cast 300? Answered
We have our own homegrown substitute for Oomoo thanks to the local boy genius Mikey77
But is there any substitute for it's companion product, the very expensive ($100/gallon), two part liquid plastic stuff called "Smooth-Cast 300"?
Does anyone know of a way to mix an inexpensive something up and pour it into a mold and have it harden up into a strong thing?  It doesn't have to be as invincible as Smooth-cast, but .. is plaster the only option?
Update:  What am I casting?  I found a really great ornamental tile at Habitat for Humanity and want to make copies of it
Update:   I'm wondering now, what if I used something from the wall/flooring department, like Mastic?  Its about $34 for two or three gallons.  It fills gaps and hardens to such a degree that it can't be chiselled easily.  I may try this.
Update:  Tried mastic, it works but takes far too long to dry, on the order of three days or longer...  Maybe if I mixed in some corn starch (ala oogoo?)
Thank you
-foo
steveastrouk
steveastrouk
Best Answer 7 years ago
How about polyester resin ?
foobear
foobear
Answer 7 years ago
I haven't any experience with it, but I'll investigate it, thank you
steveastrouk
steveastrouk
Answer 7 years ago
"Loading" the resin with a filler increases the volume you have for a given volume of resin, reduces shrinkage, and improves wearability. Its an important trick to know about. Mix in the filler BEFORE you add the hardener though.
PKM
PKM
7 years ago
You could potentially use machinable wax if your mold can tolerate moderate heat. You can make your own machinable wax from candle wax and freezer bags (https://www.instructables.com/id/Machinable-Wax/), or buy it.
There are kitchen-science ways of making your own plastics (https://www.instructables.com/id/Homemade-Plastic/) which are super cheap in volume and sound like you'll get a decently hard material at the end of it but I have no idea about curing time, shrinkage, or how easy it is to fill a detailed mold with the soft plastic.
To be honest, while $100 is enough to give you sticker shock it's not actually terribly expensive for a whole gallon of an uncommon chemical which does exactly what you need. A gallon of silicone sealant to make Oogoo with wouldn't be cheap either (though definitely cheaper than a gallon of Sugru!) Perhaps see if you can buy smaller quantities if you only need a little bit, or split the purchase with someone else who wants to do their own casting.
foobear
foobear
Answer 7 years ago
I hadn't seen the machinable wax one before. Very interesting!
foobear
foobear
Answer 7 years ago
Yeah, it may come to that, I may have to spend $100.
steveastrouk
steveastrouk
Answer 7 years ago
Why ? I can buy it in pints (well, 500mL) in the UK ? Shop around. Try sculptor supply stores.
foobear
foobear
Answer 7 years ago
Yes I am aware that it comes in pints.
steveastrouk
steveastrouk
Answer 7 years ago
Sorry, I thought you wanted a moulding material, what you want is a casting resin instead. Try a loaded polyester resin - resin mixed with a filler like limestone.
foobear
foobear
Answer 7 years ago
the homemade plastic looks too lumpy and cottage cheesey
steveastrouk
steveastrouk
Answer 7 years ago
The clues in the name : Machinable. It shrinks like a ba%$^$&rd when its cooling from liquid. Not a problem, if you're machining it
Ninzerbean
Ninzerbean
7 years ago
I've been watching a lot of videos on using 2 part expandable foam poured into molds - it's pretty amazing stuff. Let me know if that would work for what you are doing.
foobear
foobear
Answer 7 years ago
That stuff is fun
mpilchfamily
mpilchfamily
7 years ago
What are you casting?
Have you considered other mold options and using the Oomoo as your casting material?
foobear
foobear
Answer 7 years ago
I found a lovely ornamental tile at Habitat for Humanity and I want to make copies of it.
