443Views11Replies
Author Options:
Any tips on winding a toroid properly? Answered
Every time I try to wind a toroid for a circuit, it never works or it is very temperamental and does not cooperate with me. Any advice on how to wind a better toroid?        Thanks!
coolpizzadude
coolpizzadude
Best Answer 10 years ago
Did you try winding the toroid using the directions in this link that's the link I used to wind my first one.
transistorguy
transistorguy
Answer 10 years ago
Yes, I actually followed those directions in making my first one too! However I had to remake the toroid several times to get it to work.
coolpizzadude
coolpizzadude
Answer 10 years ago
Did you try this link link it says that you should evenly space the wire the around the toroid.
coolpizzadude
coolpizzadude
Answer 10 years ago
Are you using the proper toroid and transistor then.
transistorguy
transistorguy
Answer 10 years ago
Transistor-yes, toroid- I bought from radioshack, cut off their wires, and wired them myself. These are the ones I use: http://www.radioshack.com/product/index.jsp?productId=3097455
coolpizzadude
coolpizzadude
Answer 10 years ago
I am figuring are correctly winding them and connecting properly.
orksecurity
orksecurity
10 years ago
You are using insulated wire, right?
transistorguy
transistorguy
Answer 10 years ago
Insulated or enameled wire. I use both.
steveastrouk
steveastrouk
Answer 10 years ago
Insulated wire can make the coil more lossy, that's why enamelled is used.
steveastrouk
steveastrouk
10 years ago
Its a good idea to wind the wire onto a thin shuttle that you can pass through the core and keep wire tension.
transistorguy
transistorguy
Answer 10 years ago
I have yet to try that, thanks! I usually just cut a long length of wire and thread it through the toroid by hand.
