913Views23Replies
Author Options:
Any way to fix a wacky shower? Answered
Once every few weeks, the shower decides to alternate between hot and cold water. When it starts to spray cold water, the water flow is reduced first, then a few seconds later, it turns cold. It goes back warm a few seconds later. This has happened several times in the past month. Any solutions?
PhotoMaster
PhotoMaster
11 years ago
I suspect that your shower may be a cartridge based system. If your cartridge needs replacing, the symptoms you described sound like a bad or sticky cartridge. If it is a Moen, and I hope it is for you, cal Moen. They replace the cartridges for free "for life"! How do I know? Had the same problem and the same solution fixed it. Hope this helps.
Greg
bassclarinet23
bassclarinet23
11 years ago
1.) Duct tape fixes everything
2.) Call a plummer
3.) Yell at it and tell it is being a bad shower
4.) Water heater problem?
5.) Don't take a shower
:D
lemonie
lemonie
12 years ago
Does this take a single cold water feed or both hot & cold? Is there a water pump in the system? L
DJ Radio
DJ Radio
Answer 12 years ago
I dont know anything about my water system. That is a setback to solving this problem.
lemonie
lemonie
Answer 12 years ago
OK - is the shower electric - has a light, on-off buttons, temperature control? Or do you just have a big knob controlling the flow and a temperature control? L
DJ Radio
DJ Radio
Answer 12 years ago
Its a pretty old system, and It does have a big old knob controlling flow and temperature. the problems I describe only happen when I take a shower, not a bath.
lemonie
lemonie
Answer 12 years ago
Sounds like it's mixing hot and cold from your main supplies. If the flow is reduced it would suggest that someone else in the house is taking water out of the same system, causing pressure to drop at the shower. That it turns cold suggests someone is running hot water elsewhere in the house. Domestic cold water tends to be much higher pressure than hot, so you may not notice cold taps being turned on while you're in the shower (it would get hot instead of cold). Fixes: Fit an electric shower (neither cheap or easy) Re-plumb the hot water supply so that the shower is first in line, or gets a separate feed (you don't want to do that either) Check my hot tap theory and if it's true ask people not to do it... L
DJ Radio
DJ Radio
Answer 12 years ago
ok. I wish I could selected this as the best officer.
Derin
Derin
Answer 11 years ago
best officer?
DJ Radio
DJ Radio
Answer 11 years ago
typo, I had a blurry mind.
lemonie
lemonie
Answer 12 years ago
Can you not select this as the best answer, or has that already been done? L
DJ Radio
DJ Radio
Answer 12 years ago
I cant select it.
lemonie
lemonie
Answer 12 years ago
I'll post a question and see how it works - I have a serious one L
DJ Radio
DJ Radio
Answer 12 years ago
ok.
Flash Gordon
Flash Gordon
12 years ago
Maybe you can take your shower head to the shop... same thing happened to mine we got a new shower head. but its most likely the water system.
builder968
builder968
12 years ago
Here is the easiest: call the handyman.
Katarukito
Katarukito
12 years ago
If you don't like it then don't take a shower.
DJ Radio
DJ Radio
Answer 12 years ago
Then I would smell like crap.
I_am_Canadian
I_am_Canadian
12 years ago
Its probably just a appliance of yours turning on or off, such as a dishwasher, washing machine, toilet... They all use hot water, and will take some, which means less for you if you are in the shower at the time.
rich_moe
rich_moe
12 years ago
Sounds like someone is flushing their toilet temporarily dropping the water pressure, and as the water pressure returns, the mixing at your shower/bath manifold is overwhelmed by the return of cold water. The culprit could be the plumbing design of the building you live in; an example could be a bad filter in the supply line, a smaller supply line than the size of the lines in the house/appartment, or build-up of deposits blocking flow somewhere in your pipes.
randomhat
randomhat
12 years ago
Is there someone else in the house and did they run the water in the house somewhere else? Was the washer running? A dishwasher? Were you using the hotwater before the shower? It sounds like your waterheater ran out of hotwater, or there's some sort of pressure imbalance.
DJ Radio
DJ Radio
Answer 12 years ago
in every case, nobody was using the water or dishwasher. I did not use the hot water before the shower. idk what happens.
randomhat
randomhat
Answer 12 years ago
Do you by chance use a water-radiator system? If not, then there's some sort of pressure imbalance. Quite possibly air in the lines.
