3593Views4Replies
Author Options:
Anyone know how to drill holes in small stones? Answered
For use as beads.
jeasterl
jeasterl
9 years ago
first it depends on the type of stone soft stones like Soapstone and pumice can be drilled with regular bits take it slow and clear the dust often don't use your best most expensive bits carbide masonry bits hold up better if you can find one in the right size
hard stone like granite or volcanic glass i would use a diamond bit keeping it cool with some water
to drill deep holes in hard stone (an inch or more) make a little dam around the location for the hole with clay fill the 'lake' with an abrasive like valve lapping compound (silicon carbide) and use a steel or brass rod in a drill press go slow and keep the well filled with water and compound
Zippomanonfire
Zippomanonfire
12 years ago
Wrap the stone in cloth or other protective material. Put the stone in a vise. Get a Dremel with a small drill bit, diamond tipped if possible. Use a rather low speed, I set mine to about 4 or 5. Periodically pour cold water on the stone and bit to cool it down. It ends up taking longer using a lower setting, but it doesn't heat up as fast so you'll save bits. Depending on the type of drill bit you use, you probably wouldn't want to use it on anything else afterwards.
