4147Views12Replies
Author Options:
Anyone know of an adhesive for Lego's that can be undone by say, soaking in water or something else? Answered
I've just been thinking Lego's would be more useful if the bond was stronger.
dpv882
dpv882
9 months ago
What about clear nail polish, and nail polish remover to undo?
stutzmaster
stutzmaster
11 months ago
flat peices hold together better than the thick ones, and u wont need to dissovle anything in water to sperate
acidbass
acidbass
10 years ago
super glue a mixture of flour and water Elmer glue tiebond 3 poly and the car stores sell a plastic to plastic adhesive that pries apart it is used for the emblems on the cars
DREWSR
DREWSR
Answer 10 years ago
I never expected to actually get an answer to this question. Thank you for taking the time!
steveastrouk
steveastrouk
10 years ago
How abuut using a "composite" and gluing paper to the inside of the model with PVA ? That should all soak away in warm water, and it will be a lot stronger than just PVA/Elmers
caarntedd
caarntedd
10 years ago
Polyurethane sealant. Sticks good, peels off plastics easy.
Kiteman
Kiteman
10 years ago
Stronger?
What are you trying to build?
lemonie
lemonie
10 years ago
Epoxy will "pick-off", the plastic is quite resistant to it - it doesn't really "stick" it more "adheres".
L
rickharris
rickharris
10 years ago
PVA -Eelmers glue - isn't water proof although it may need soaking to loosen, Super glue also gives way when soaked.
NachoMahma
NachoMahma
10 years ago
Elmer's Glue All* will dissolve in warm water, but it' may not stick very well to the slick plastic used for Legos.
* It did last time I used it, but that was about 15 years ago and the formula may have changed.
nickodemus
nickodemus
10 years ago
I don't know of anything that would be dissolvable in water...
I'm fairly sure most PVC glues were meant to be water tight. So if you don't mind it being permanent, try using pvc glue. If you want to see how well it would work, just test it on some lesser pieces that you wouldn't mind losing.
