85Views3Replies
Author Options:
Arduino Blink Code help? Answered
I have just started learning the arduino. I have also started to learn basic C so I am familiar with for,while loops,etc.
I'm working on a circuit that when triggered using a pusbutton, an LED blinks 5 times with a 1 second delay between each state and then switches off until triggered again.
I need help in writing the code.
steveastrouk
steveastrouk
6 years ago
You're using "rightsig" and "leftsig" as constants and variables, so it won't work. Use "cnt" as a counter variable in your for loops, you can use the same name twice, because only one counter is working at a time.
steveastrouk
steveastrouk
6 years ago
"Is it right ?"
Does it work ? If it does, its right, if it doesn't it isn't.
Jonathanrjpereira
Jonathanrjpereira
6 years ago
I tried to write some code is this right. NOTE: in the code below i am using two buttons for two LEDs:
int leftsig= 9;
int rightsig= 10;
int buttonstate1=0;
int buttonstate2=0;
int button1= 8;
int button2= 7;
int i=0;
int j=0;
void setup()
pinMode(leftsig, OUTPUT);
pinMode(rightsig, OUTPUT);
pinMode(button1, INPUT);
pinMode(button2, INPUT);
void loop()
buttonstate1= digitalRead(button1);
if(buttonstate1==HIGH)
for(leftsig=0;leftsig<5;leftsig++)
digitalWrite(leftsig,HIGH);
delay(1000);
digitalWrite(leftsig,LOW);
else(leftsig,LOW);
buttonstate2= digitalRead(button2);
if(buttonstate2==HIGH)
for(rightsig=0;rightsig<5;rightsig++)
digitalWrite(rightsig,HIGH);
delay(1000);
digitalWrite(rightsig,LOW);
else(rightsig,LOW);
