263Views9Replies
Author Options:
Arduino Current Sourcing for Common Anode RGB Answered
Question:
Is it safe for the arduino to sink more current then the arduino is sourcing? (see diagram below)
My project requires 12 of large 10mm RGB leds,  broken down this is 36 leds in total, which exceeds maximum draw,  the design calls for the LED's to share a 5v+ from a seperate 5v regulator, then sink each pin to low to turn them on
is this correct?
iceng
iceng
4 years ago
A nice drawing deserves another...
Be sure to click the pic, to view the whole image.
iceng
iceng
Answer 4 years ago
A 5V emitter follower common cathode LED version
steveastrouk
steveastrouk
Answer 4 years ago
OK, if you have the head room on the drive to overcome the load drop.
iceng
iceng
Answer 4 years ago
Cant imagine the OP will respond or even knows what is happening..
iceng
iceng
4 years ago
Maybe you seek a lower power driver like a MOSFET with resistor adjustment for each LED Forward Voltage.
Be sure to click the pic, to view the whole image.. -.-. . --. -.
seandogue
seandogue
4 years ago
Ideally, you want to ~isolate the Arduino's I/O circuitry from real world loads by using an intermediary circuit for driving loads.
Downunder35m
Downunder35m
4 years ago
It does not really matter which way you look at it if you look correctly.
An Arduino is a microcontroller but not a power switch.
That mean logic levels only but nothing to power things up.
All pins on most Arduinos are designed for little electronics projects and if you check the Arduino Playground you will realise that everything else runs through transistors/mosfets and external power supplies.
Create a nice matrix for your LED's and reduce pincount this way.
Then use suitable transistors and current limiting for the LED colors and you are good to go.
steveastrouk
steveastrouk
4 years ago
Depends on the current, which you don't state. Not only is there a PIN limit, there is a port limit, and a PACKAGE limit which mustn't be exceeded.
Broadly, you must sink NO more than 40mA per pin ABSOLUTE MAX, and happier to stay at 20mA, and NO MORE than 200mA, all up, on all pins.
The best way to do this is to use drivers designed for it, like the ULN2803
iceng
iceng
Answer 4 years ago
+1
