195Views5Replies
Author Options:
Arduino Relay? Answered
I'm working on a UPS of sorts for an arduino project of mine. Basically if the pwoer goes out I want the arduino to switch to a 9v battery backup. I was wondering what sort of relay I should use and if a transformer would be needed. Ideally I'd like to use a simple power supply with a transformer built in and then have that feed into the relay, but I'm not sure if the 7-12v from a normal arduino power supply would then be enough to switch the relay (normally closed).
iceng
3 years ago
Here is your automatic and instant switch over schematic.
You could even add a resistor from the 12vDC supply to trickle charge the 9vDC Batteries.
iceng
3 years ago
If the pwoer goes out so will any PS and most transformers.
Just use a diode from the 9v to take over when the higher voltage stops.
This will happen instantly compared to a relay.
FarmerKJS
3 years ago
I would have it on all the time in case the sump fails.
You will have to experiment a little to see if it will reboot.
It could probably send an email pretty quickly... Depending on how it is programed
FarmerKJS
3 years ago
Just a simple 5 pin relay. I will add a schematic as soon as i draw it
FarmerKJSFarmerKJS
Answer 3 years ago
If its unclear just ask for clarification.
