123Views6Replies
Author Options:
Arduino Serial monitor to LC Answered
UPDATE
I manage it to work, now i have a short, cross and continuity tester for cables.
PM if u need the code.
Best regards,
Paul L.
Hello everyone,
Can some help me to change the code in order to use a push button to start the test and all the result to be moved from serial monitor to an LCD with I2C, the address of the LCD is (0x27) and it`s useing pin21_SCL, pin20_SDA 5V and GND.
If its anyone with more experience then me and could do that, the help is welcome :)
Download the Code <- here you will find the code named test28.ino and the LCD code that I used to test the LCD, and a text file with the pins used by the LCD.
Thank you,
Paul Lungoci
steveastrouk
1 year ago
Does your LCD test work OK ?
Steve
steveastrouk
1 year ago
I assume this is about an Instructable you are viewing. Post the question in there, and perhaps the original author can help.
LungociPsteveastrouk
Answer 1 year ago
Its not about an Instructable that i funded here, its about finding someone that can help me modifying an arduino code that is using serial monitor to interact with the program instead of and display 16x2 and a push button.
steveastroukLungociP
Answer 1 year ago
OK, so post your code ! How can we tell if we can help otherwise ?
Which LCD are you using ?
