3206Views7Replies
Arduino as USB-client?
I was searching for something fun to make with my arduino when I came across this:
http://www.practicalarduino.com/projects/virtual-usb-keyboard
I tried to make it work but it didn't work for me. could that be because I used 3.3V zener diodes?
If you made something according to the link did it work for you?
9 years ago
I doubt its the zeners. Did it ennumerate ?
Steve
Answer 9 years ago
my problem is the computer doesn't recognize the arduino(I should have mentioned).
and what exactly do you main with "Did it ennumerate ?"
Answer 9 years ago
The process of the computer recognising your device is called ennumeration.
Try reversing the data lines and see what happens.
Its a clever, and very complex piece of code you're playing with.
Steve
Answer 9 years ago
I finally had some time reversing the data lines.
but now it does nothing, the computer doesn't even see my arduino.
Answer 9 years ago
You SAID it didn't see your arduino the first time !
I would add some debugging code and run the Arduino's own serial port to your PC as well.
Answer 9 years ago
ow sorry, the first time the computer said: "device not recognized" (with the error code 43 http://technet.microsoft.com/nl-nl/library/cc725873(WS.10).aspx)
I'll try the debugging but I think you have to help me with that a bit. I'm still quit new in the arduino world.
Answer 9 years ago
You've picked a particularly complex project to start with then !! The V-usb driver stack is not the easiest thing to steer by the look of it.
There will be other things you need to set in the code I suspect. The REFERENCE project that this is based on is here
http://www.obdev.at/products/vusb/hidkeys.html
The arduino USB library you need is here:
http://code.google.com/p/vusb-for-arduino/downloads/detail?name=vusb-for-arduino-005.zip
