195Views6Replies
Arduino custom shield isn't working right...
I've been trying to figure out whats wrong on the shield i built for my intervalometer project but somehow nothing is working except bottom row of the screen (standard 16x2) is all lit up. I've checked my wiring, shoddy as it looks, several times over but nothing seems amiss. WTF is wrong?
Then tonight it occurred to me, perhaps its the Vin pin that I neglected to put in since I wasn't going to need it for this project is the cause. Am I close to what might be wrong?
9 years ago
You've not initialised the screen properly ? Are you in 4 bit or 8 bit mode ? Do you have a contrast pot connected properly ?
Answer 9 years ago
Its supposed to be in 4 bit as far as i can tell, im just copying requisite code from arduino's lcd library for the hd44780 controller.
Answer 9 years ago
Make sure its getting the initialisation codes it needs, and make sure the UNUSED pins are tied to ground.
Answer 9 years ago
I dont think the chip or arduino as a whole is borked since it will upload fine and it'll blink the onboard led and it'll read the rotary encoder button (haven't gotten it to read the rotary encoder proper yet :/ ).
Answer 9 years ago
Where did I say it was borked ???
Check what I said.
steveastrouk says: Make sure its getting the initialisation codes it needs, and make sure the UNUSED pins are tied to ground.
Steve
9 years ago
They're certainly not the best, I don't have a fantastic iron, but they're not bridged if that's what you mean.
9 years ago
photos added
9 years ago
I'll see what I can do, but the Vin pin is just a power pin, from arduino.cc "VIN. The input voltage to the Arduino board when it's using an external power source (as opposed to 5 volts from the USB connection or other regulated power source). You can supply voltage through this pin, or, if supplying voltage via the power jack, access it through this pin. "
