535Views6Replies
Author Options:
Arduino file extension Answered
I haven't been using Arduino for a while but there is something going on with the file extensions. When i rename and save a file the extension gets changed and it can't be opened again. Just adding .pde or .ino doesn't do it. I am using .022 and 1.0.5 for some applications so i think going between them is causing the problem. Is it possible to find a common file name or remove the extension preferences so i can retrieve my sketch.
mpilchfamily
Best Answer 5 years ago
You shouldn't be renaming the files. Just open them up in 1.0 and save them as a 1.0 file.
WWCmpilchfamily
Answer 5 years ago
What if i wanted blink1 and blink2, is it not appropriate to rename them to that title to keep seperate.
mpilchfamilyWWC
Answer 5 years ago
Don't rename them by clicking on the file. Open the file in the IDE and then Save As to save it as a differnt name.
WWCmpilchfamily
Answer 5 years ago
Alright i will try that. If i have a file that the extension has been changed, how to change it back.
mpilchfamilyWWC
Answer 5 years ago
Rigth click, Open With, Notepad. Save As a notepad. Then edit the extension to what you want. This should allow the IDE to open it.
WWC
5 years ago
Thanks
