290Views1Replies
Arduino soda fountain?
I would like to make a arduino soda fountain but i need some advice.
Heres my plan Take an 8 channel relay board hook it up to the arduino. Then I take a 8 key keypad and hook to the arduino.
I would buy 8 solenoid valves and hook them to relays. The valves would hold 1 water line and 6 flavors. Then i get stumped how do i get the last line to be carbonated water because if you had to take a soda stream to make the water it would take away from the effect of the machine.
If any body knows how to do that i would love to hear
I will also take any other advice
Thanks Kaden
6 years ago
Check this out
You need a Tank of C02 to do this without loosing most of the carbonation
Non carbonated drinks would work well ! Otherwise you need a borderline Commercial system. Check Craig's list if your aria could be a used system?
But otherwise your solenoid and relay system would work for non carbonized drinks :)
You will need at minimum a bar fridge to hold this in mind you ! There are many containers to fit in a small space.
