78Views5Replies
Author Options:
Atx supply possible Wattages Answered
Hi there community, i have a very certain question.
I recently modified an atx supply of 420W. Some of its features are :
5V 32 A
12V 14A
3.3V 22A
-12V 0,5A
Lets say i connect one end to 5v and the other to -12v, what wattage will this give me ? Probbaly not 17x32=544
Is bridging possible? What are the possible wattages ?
Thank you for your time :)
phevtron
1 year ago
Thank you for the answers kind strangers !
My basic question was the one you both answered. Maximum amperage is therefore the lowest available from a rail, got it
rickharrisphevtron
Answer 1 year ago
Correct. Essentially you can't get something for nothing.
Jack A Lopez
1 year ago
The numbers for current, printed on the nameplate of your power supply, represent the maximum current that rail can comfortably supply.
The actual current drawn by a load, depends on the character of the load.
Anyway, you asked about a hypothetical load, connected between the +5V rail and the -12V rail. What is the maximum current that could comfortably be supplied to this load?
The answer is 0.5 A, because that is the maximum for the -12V rail.
How much power dissipated by this hypothetical load with 17 volts across it, and 0.5 amperes, maximum, flowing through it? Answer: a maximum of (17 V)*(0.5 A) = 8.5 W
By the way, the people who sell power supplies, often try to make the numbers seem big, because big power is sexy, obviously.
I was expecting the number 420 W, to be the sum of all those individual rails, supplying the maximum rated current.
Specifically:
(5V*32A)+(12V*14A)+(3.3V*22A)+(-12V*-0.5A)
= 160W +168W +72.6W + 6.0W
= 406.6W
which is close to 420W, but not exact. I dunno. Maybe they rounded it up to 420, because that number sounds good?
Final note: I do not grok this thing you call "bridging". I just do not get what you are asking about that. So I cannot say if that activity is possible to do that, or not, with your power supply.
I have heard of "planking", but I think that is something different than "bridging".
phevtronJack A Lopez
Answer 1 year ago
What i mean by bridging is a process available in common transformers where wiring them in different combinations provide different voltages or amperage. But i suspect this is not possible( asked to be sure).
My google search gave no results about atx supply planking, please provide more info
rickharris
1 year ago
You can't exceed the lowest available power. Your -12 volts will only supply 0.5 amps.
