6419Views14Replies
Audio chip?
I want to make a device to play a sound when a PIR sensor detects motion, but I don't know about the audio chip. I can't seem to find a chip that allows you to program a sound clip to it, then output it when it is given a signal. The closest I found was a cheap sound recorder module from china, but it contains all the external components (mic, batteries, speaker, switches) and so it acts just as a voice recorder. I need an individual chip that will do something similar. I may use the module as a prototype, but I eventually intend to mass produce the circuit, so that is why I am looking for an alternative. It only needs to hold about 5 seconds worth of audio, medium quality.
Best Answer 9 years ago
Now, I am not totally certain on this, but I think PICAXE chips with an M in the name (08M, 14M etc) can play music. If they can, then it should be relatively easy to do. Type PICAXE Manual 1 into google, and see if there is anything in there.
Answer 9 years ago
I will check those out, a micro controller capable of playing audio would be perfect.
Answer 9 years ago
He is correct they do
9 years ago
Lol, a talking/singing Hallmark Card came to my mind. Is there any way to make it into what he is talking about?
9 years ago
Ti used to make a small IC that could be prerecorded for sound as part of a gaming event. I can't find anything like that in their product line now ??!
9 years ago
ISD5116 is a record playback 8min IC
others are available.
A
Answer 9 years ago
Thanks, I will have a look at this, but it seems unnecessarily large. I only need to store a few second-long audio clip on it, not 8 minutes. The packages seem a little bit too large as well, and they don't seem to have a DIP option. I need a chip which has a DIP package for prototyping, but is also available in a small QFP or SOIC for mass production. What about the programming too? How would this be done?
Answer 9 years ago
I gave you the longest time of the group you can get 10 sec units.
Answer 9 years ago
Absolutely. The ISD chips are fantastic for this kind of application.
Steve
9 years ago
What sort of sound
What is your skill level with electronics
What experience have you of using microprocessors.
What budget do you expect.
All these are relevant to a sensible answer.
Answer 9 years ago
I have a lot of experience with electronics, but I haven't really properly used microcontrollers. I have a PIC programmer, but I couldn't get it to write any custom code, I also have an arduino, but I have only got tutorial code running on it. I also have a few ATTiny 2313-20PUs, apparently I could program them through my arduino, but I was never able to make this work. Budget isn't too important as I am creating a prototype on behalf of someone, so it should be a fairly common chip that can be bought in a DIP package or QFP/SOIC for manufacturing. I can't give you all the details on the sound as it is classified as the patent for the idea is still pending, but it will be a short sound effect, that needs to be medium quality, and it will be amplified to about 500mW through an LM386.
Answer 9 years ago
Go with the picaxe it's easy to learn. My door bell is driven by a picaxe = plays music.
The forum with hel with any other questions.
9 years ago
I think there was a fetured article in the last few months showing how to work with audio on an Arduino, and I expect some of this can be transferred over another microcontroller suitable for your project.
Answer 9 years ago
I will have a look at this. It may be alright for a prototype anyway.
