1810Views7Replies
Author Options:
Auto stop 12v pump (no float-switch)? Answered
Hi guys, i got a very urgent question,
I need a mini small water pump just as the wiper pump 12v  but the most important thing  I need it to stop when the water tank is full (auto-stop) with no need of a float-switch.
So how can i find this type of pump and what is their right name of the pump
or what is the key-words that could give me the right on google
 this is my first question link
 https://www.instructables.com/answers/Water-dispenser-or-cooler-Pump-system-/
Thanks, Pls instructables community help me !!
steveastrouk
steveastrouk
Best Answer 6 years ago
Peter's circuit's a good way to do it.
vwtm2006
vwtm2006
Answer 6 years ago
thanks guys, but i need something simple , i am searching for a mini pump 12v that have a pressure sensor or on demand system
i need the name of this type of pumps
thanks community
steveastrouk
steveastrouk
Answer 6 years ago
simple is a float switch. Pressure switches arenot going to work without a lot of tricky work, because the thing won't have enough discrimination - you have 2 metres of height, and your tank is 200 mm high.. There is 10 percent pressure change in 1/5th of a Bar. The sensor is not cheap, or simple
tgferreira184
tgferreira184
6 years ago
Maybe a water switch (two exposed wires close to each other on which the water closes the circuitwhen touching it) and if needed a relay.
Josehf Murchison
Josehf Murchison
6 years ago
You know I never thought about the important question until red Steve, Rick and Petecd comments.
What kind of water and will it have living things in it?
Small amounts of current bother and can kill living marine life in fact it only takes 4 ma to kill a person.
I never rely on waters continuity, distilled water is an insulator until you add a trace element just like a semiconductor. If you take pure water electricity won’t pass through it, add salt or acid to the water and electricity will pass through it just like a semiconductor.
So what kind of water?
Joe
Josehf Murchison
Josehf Murchison
6 years ago
All reliable water controls use some kind of float system just all float
systems don’t use floats.
Take a washing machine for example the float is air, as the washing mashing fills with water it seals and fills a tube with air sealed to a diaphragm switch the higher the water level the higher the air pressure in the tube. When the air pressure reaches the desired point it trips the diaphragm switch to turn off the filling solenoid turning off the water.
Yes I was an appliance repair man.
It is a simple diaphragm switch but it can be complicated to set up, you may need a large tube pushing air into a small tube to create the air pressure needed to
trip the diaphragm switch.
Joe
petercd
petercd
6 years ago
This is what I used as the auto fill circuit on a 12V washer pump for one of my hydroxy cells, the fet came out of a 14" monitor with its own heatsink.
