299Views5Replies
Author Options:
Band saw part missing? Answered
Need a little help here. This is a craftsman 10" band saw. The image is directly below the cutting surface. I suspect there is a part missing, maybe a guide or roller. Where the arrows are in the picture, there are holes as if a bar should go across to hold a roller.
Can someone please confirm there's a part missing, tell me the name of the missing part and hopefully where I can order a new one?
One day I was cutting, the blade broke. No big deal, right? I put a new blade on and continued working. It runs pretty well, but the blades pop off pretty easily. It gets very frustrating. Later, I found a wheel (about less than 1/2") in the sawdust. It could only have come from the bandsaw. I didn't find any other parts, but they could have been sucked up by the vacuum.
Thanks for the help!
rickharris
rickharris
4 years ago
What you have lost is the lower blade guide. Not too difficult to make a new one see here:
there is very little Matthias can't make.
Yonatan24
Yonatan24
Answer 4 years ago
*Nothing, I think you meant :)
rickharris
rickharris
4 years ago
Actually looking closer I think you have a bottom guide, not a very good one but the blade isn't between it.. The blade is also too slack.
Quadrifoglio
Quadrifoglio
4 years ago
If you have the manual, check in the back. There should be an explosion diagram, like this one https://www.manualshelf.com/manual/craftsman/113-244513/band-saw-owners-manual/page-18.html, and a parts list like this one https://www.manualshelf.com/manual/craftsman/113-244513/band-saw-owners-manual/page-19.html.
Check the Sears “Model finder” at http://www.searspartsdirect.com/. Pull the lower guide and see what has gone wrong and what you will need. Don’t be surprised if the part or parts are discontinued (everywhere). Fortunately, rickharris has a elegant solution.
g-one
g-one
4 years ago
Indeed it seems the rear thrust bearing for the blade is missing. Often the blade guides above and below the cutting surface look similar. If you find such a small wheel at the upper blade guide as well it would be quite likely the missing bearing for the lower blade guide. Maybe some pictures will help you
http://www.google.com/images?q=band+saw+blade+guide
