79Views2Replies
Author Options:
Batch programming: this doesn't work? Answered
Ok, so I've been making a program that tells jokes (just as a test). What I'm trying doesn't work for some reason, and I don't know why. Can you tell me how to fix this, or give me a new code that does the same thing but without a separate .txt file?
Here's the code:
@echo off
title Joke Test
color 0a
:joke
set /a joke=%random% %% 6+1
if %joke%==1 do (
cls
echo.
echo           What is the stupidest animal in the jungle?
pause > nul
echo.
echo                       The polar bear.
pause > nul
goto menu
if %joke%==2 do (
cls
echo.
echo            Where did Mary go after the explosion?
pause > nul
echo.
echo                       Everywhere!
pause > nul
goto menu
if %joke%==3 do (
cls
echo.
echo                  Knock knock.
pause > nul
echo.
echo                  Who's there?
pause > nul
echo.
echo                  Europe.
pause > nul
echo.
echo                  Europe who?
pause > nul
echo.
echo                  No ur a poo!
pause > nul
goto menu
if %joke%==4 do (
cls
echo.
echo       A man walks into a zoo. The only animal there is a dog.
pause > nul
echo.
echo                       It's a shitzhu.
pause > nul
goto menu
if %joke%==5 do (
cls
echo.
echo           What do you call a kid with facial deformation?
pause > nul
echo.
echo                           Names.
pause > nul
goto menu
if %joke%==6 do (
cls
echo.
echo           What did the pirate say on his 80th birthday?
pause > nul
echo.
echo                          Aye matey!
pause > nul
goto menu
TheBigRoosterYo
3 years ago
Ok, I've found a way to fix this. Don't know why this works, but it does.
@echo off
title Joke Test
color 0a
:joke
set /a joke="%random% %% 6+1"
if %joke%==1 goto joke1
if %joke%==2 goto joke2
if %joke%==3 goto joke3
if %joke%==4 goto joke4
if %joke%==5 goto joke5
if %joke%==6 goto joke6
:joke1
cls
echo.
pause > nul
echo.
pause > nul
goto joke
:joke2
cls
echo.
pause > nul
echo.
echo Everywhere!
pause > nul
goto menu
:joke3
cls
echo.
echo Knock knock.
pause > nul
echo.
echo Who's there?
pause > nul
echo.
echo Europe.
pause > nul
echo.
echo Europe who?
pause > nul
echo.
echo No ur a poo!
pause > nul
goto menu
:joke4
cls
echo.
pause > nul
echo.
pause > nul
goto menu
:joke5
cls
echo.
pause > nul
echo.
echo Names.
pause > nul
goto menu
:joke6
cls
echo.
pause > nul
echo.
echo Aye matey!
pause > nul
goto menu
Downunder35mTheBigRoosterYo
Answer 3 years ago
It works because you now have defined IF functions and you use "jumps" (goto).
Before you created a random number to select a joke without creating a loop for it so the program would only run once.
Rocketsurgery had a great idea with the arrays, you should incorportate it as it makes the code easier to change for new jokes.
The best option however would be to actually use an external textfile and variables for the text array and length.
So your first variable is read from the amount of lines within the textfile and sets the array for the ramndom number.
The next would be the one for actual joke, but if in doubt you can use the first for this as well.
And instead of the "IF - GOTO" routines you read the lines for joke from the textfile directly based on the random number.
This way you can add to the textfile without the need for any code changes.
If you want to keep all within a single file you can use the arrays as a block, read it out and use variables in a similar way but the coding is a bit more complex for this.
rocketsurgery
3 years ago
You could also use arrays to store your jokes
SET Joke[0,0]=How many surrealists does it take to change a lightbulb?
The answer would be...
SET Joke[0,1]=The Fish.
You would then randomly choose the joke and for loop until the joke was complete...
using something like echo !Joke[%JokeSelected%,%LineNumber%]!
See below as an example using separate arrays for question and answer (I would prefer the 2d array as above)...
@echo off
setlocal EnableDelayedExpansion
Set NumberOfJokes=5
SET Question[0]=What is a physicist's favourite food?
SET Answer[0]=Fission Chips.
SET Question[1]=What do you call two crows on a brach?
SET Answer[1]=Attempted Murder
SET Question[2]=My band is called 1023MB
SET Answer[2]=We haven't yet had any Gigs.
SET Question[3]=A photon hops on a plane with no luggage...
SET Answer[3]=He was travelling light.
SET Question[4]=Hear of the man who was cooled to absolute zero?
SET Answer[4]=He's 0K now
SET /A JokeSelected=(%RANDOM% %% %NumberOfJokes%)
echo !Question[%JokeSelected%]!
pause > nul
echo !Answer[%JokeSelected%]!
pause > nul
