96Views5Replies
Author Options:
Batteries in a series? Answered
So if you were building an electric car and needed to up your voltage by wiring multiple Pb batteries in a series would you only get the watt-hours of one battery like you do with capacitor capacitance, or would you get all of them combined, or at least a little power capacity boost.  Also, would using lithium-ion batteries like these in a series be ok. lithium
jj.inc
jj.inc
Answer 8 years ago
Oh, darn. So how on earth do I get 96v and still maintain a reasonable price and run-time. This is the setup I am looking at, how long will 8: 12v, 589 Watt-hour, 106 reserve capacity batteries last at max motor power.  I figured these batteries would only be around 40 amp-hours per series, and I would need about 600 amp-hours to run for an hour.
steveastrouk
steveastrouk
8 years ago
You get the combined Ah, and, since the voltage is increased, you get increased Wh.
Lithium ? Yes, sure, if you use a proper charger.
jj.inc
jj.inc
Answer 8 years ago
So the 8, 40 ah batteries I would need to get the voltage up would also give me 320 ah total. That's great!!!! I guess I won't be needing 300 or so batteries I expected. Is weight the only benefit of lithium?
steveastrouk
steveastrouk
Answer 8 years ago
No, they have zero memory effects, within their charging life, they also hold charge very well - self-discharge is a problem in other chemistries, like Pb.
Their output voltage is also pretty stable during the discharge cycle too.
Steve
