91Views9Replies
Author Options:
Battery Powered Lightbulb Answered
Is it possible to power a household size incandescent lightbulb with a battery? If so how?
rickharristhematthatter
Answer 4 years ago
Poster could be in the UK or Europe and then will need 20 car batteries.
-max-
4 years ago
You can power any low wattage 120V appliance with a inverter, you do not need to replace the filament. You can make a inverter by using a large 120V to 12V transformer, and feeding the 'secondary' coil with 12Vac to run the transformer in reverse and boost the voltage up to 120V.
rickharris
4 years ago
1. Directly no.
2. If you want battery powered light and a normal sized bulb you will have to dismantle the bulb and replace the filament with LEDs.
3. You could use the LEDs anyway
Downunder35m
4 years ago
You are better off using a LED light instead.
Not only can you use lower voltages but you need a lot lees energy to get the same amount of light - which is what you want on batteries.
A normal lightbulb give light ok, but mostly it produces heat.
-max-
4 years ago
With a 12V to 120V inverter.
Downunder35m
4 years ago
Before we had the fancy LED lamps all flashlights used incandescent light bulbs, same on push bike.
iceng
4 years ago
The bulb design voltage must NEVER Ever be less then the battery voltage !
Then wire the bulb across the battery without regards to polarity :-)
