101Views2Replies
Author Options:
Battery operated led with 6 hour run time per day. Answered
Trying to figure out how to make a circuit for a LED light that is run by two AA or two C batteries. I would like the light when turned on to run for 6 hours and then turn off. Then autmatically turn on the same time each day and run for 6 hours without having to manually reset the light. Having a hard time trying to figure out how to make this timer. It would also be a bonus if the the led flickered like a candle. Thanks for any help in the right direction.
Shadowmang
Shadowmang
12 years ago
possibly you could just build the led circuit and add one of those light timers for lamps and stuff. Thats how I would do it but I'm not very good at electronics and programming :x
killerjackalope
killerjackalope
12 years ago
Well 2700mah X 2 = 5400mah @2.8V So it would need to be stepped up slightly to make it light the LED but @ 30ma it'd run for 180 hours direct, or have I just been very silly, assuming the circuitry took it up to 100ma you'd be looking at 54 hours of runtime.
As for the circuit used a super simple clock circuit could be used, a 555with a massive capacitor or some kind of counter module, a PIC chip wouldn't need much complicated programming to do both the timing and the candle flicker.
Remembering the stepup necessary to make the LED work a small boost converter or even a clever joule thief circuit could work, actually a joule thief and a camera quality rechargeable could be used as a single battery but you'd need to get the transformer tuned to be running at the right voltage.
hope that helps, some clever person will probably say something deserately simple now.
