29Views3Replies
Author Options:
Bearings need replacing??? Answered
My saw has recently started dragging down during cuts, the harder the wood the more it drags. I have to feed the work piece very slowly. The first few years it never did that. I don't use it too often but it is 10 - 12 years old. It is a Delta table saw. The only maintenance I've done is cleaning out the saw dust and waxing the table.
mikeasaurus
Best Answer 1 year ago
Is your blade sharp, and are you using the right type of blade?
Hard woods will take longer to cut as the blade has to work harder to cut through the material. However, you can make faster cuts by using a blade with a low tooth count. Tooth counts on blades are discussed in the first lesson, linked to the relevant part here.
A dull blade will also cut very slowly. Considering the table saw is 10-12 years old I'd say it's time to invest in a new sharp blade (and have a spare blade with a different tooth count as backup/to switch out when needed).
You might be right about your saws bearings, but a much easier and inexpensive solution could be just replacing the blade. Good luck!
oky jimmikeasaurus
Answer 1 year ago
i am 72 yo and have been working wood since i was 10. I have in that time only encountered 1 saw that had bearing problems so I doubt bearings are the problem. I agree the type and sharpness of the blade are much more important. The thickness of the blade can be a factor and I have recently started using the inexpensive Freud thin kerf carbide tipped blades that are sold in places like Home Depot. This started when my large kerf blades bogged down on a garage sale find that had a 1 hp motor. I couldn't believe the saw was bad, the motor checked ok and there was only 1 other thing to check ...the blade. I bought a Freud and installed it...Wow it zipped right through tough Oak, Madrone , manzanita, pitch filled pine...no problem. I had an old craftsman in the back of the shed and put a blade on it and it performed like a new saw. After using it a while I looked at the motor,,,it was only a 1/2 hp and performed like a 1 hp with the new blade. Definitely consider the blade....
carl5blummikeasaurus
Answer 1 year ago
Hello: A new blade is a good idea. Plus if your old blade is straight steel do try carbide tipped blades. Even the cheap ones cut much better, and I once bought an expensive one with anti-vibrations slots, etc. Was that ever a great blade!
A different question: Is your saw dragging down during rip cuts? It could be the wood is closing down on the blade.
Carl.
