107966Views22Replies
Author Options:
Best magnet size to coil size ratio for an electromagnetic generator? Answered
what is the best magnet (neodymium - disk shape) size to copper coil size ratio for optimal electron production per one break/pass of flux lines across coil at a 1/2" distance? For instance, if magnet is 2" diameter what is best inner diameter for copper coil? Best number of windings? Best gauge wire? what are the best specs for optimal electron production before you reach "over kill". I know some things are variable like core material and magnet grade. I'm looking for an all things being equal kind of scenario. Also what would be the best thickness of magnet at 2" diameter? If anyone could point me in the direction of any existing tables or ratio information on this subject it would be appreciated. Thank you.
zeego
zeego
1 year ago
mate I think you are in the right direction of magnet set up.just don't use round magnets,use rectangular shape instead.i have been doing things like this as experiment.i tried using round magnets passing thru the hole of the coils as well and gives me a good result but the problem is the set up of gears to make it passing thru the coil hole without touching the coil unit while spinning.just need a precise machining as a whole unit really.but really it works.my cnc machine is too tiny for that job...have a review on magnet principle it will help you much.
vijaybhai.lathiya19
We have to wires 26 swg gauge and 16 gauge. we are designing a VAWT we get nermal out put rpm of 60. We are having problem in calculating no. Of turns for both deferent gauge of wire so we kindly request you to help in our calculation .
mahesh.pagda
mahesh.pagda
4 years ago
i want to make small unit of wind turbine generator.so,i am confuse about how much gauge is for makeing coil.
mikefarley001
mikefarley001
Reply 1 year ago
depends on the amount of current that will be going through the copper. id say 18 gauge to 20 gauge, probably 20 but that is up to you and your project. if your making it for orgonite, it depends on the size of the orgonite. if its for free energy stuff, depending on the size of the project, if its small i would say 20- 22 gauge but if its a bit larger id say 18 guage
RussellB71
RussellB71
1 year ago
I've been designing many types of wind turbines, and it just seems odd that silver wouldn't be used for generator coils, as its 7% more conductive then copper, but I have come a crossed a copper alloy that's more conductive then silver, but can't find it online anywhere. I believe the alloy was 0.005% lithium and the rest Copper.
WilliamC329
WilliamC329
3 years ago
Use computer neon lights they light at 5 volts
K-10K
K-10K
4 years ago
Can any one help me to build my wind turbine ? I have make 12 mag ( Ferrite ) 9 coil Generator With 1.2 mm dia 220 turns and 345gms of copper coil i get 3.7v ac and 2.5amp Another experiment 0.91mm 290 turns and 275gms copper coil i get 5v 2amp This values are of one coil Now i am confused what i should use Can any one guide me?
RicksterInstructables
I have the same questions as many posters here.
I have a striking engine and would like to light (or blink) an LED.
The thing has a six inch diameter flywheel. My best experiment so far is to line the entire outer rim of the flywheel with these thin 1/4" square rare earth magnets - all in a line, alternating polarity. I then use a commercially bought 24v electromagnet as a pickup coil. I can get 0.4VAC.
I've tried home made coils and open solenoid so (air Cortez) and ferrite core, and spacing the magnets further apart... Everything else gives me at least an order of magnitude worse. I'm able to use a diode/capacitor voltage quadrupled ladder to build up a decent enough voltage to fire an led. Now I just have to figure out a circuit to fire it and then let it recharge (any 3 volt neon bulbs lol) - ideas?
I have this feeling that the adjacent alternating the polarity of the adjacent magnets causes the flux lines to "dive" back into the adjacent magnet rather than penetrating the coil. Any ideas on how to get the flux lines to "project"?
I imagine the best way is two disks with magnets on each with a strong field between with the coils in between? Unfortunately, I don't have the real estate for that.
If I get the electromagnet (iron core) too close to the magnets, it attracts things and stops the motor.
Would/should an air core work as well/better in this regard if I wind enough turns? (It's 223ohms, so that'd be quite a few feet of 30/32/34awg wire).
Any help would be greatly appreciated.
Any pointers to a circuit that would trigger the LED when the cap charges to, say, 4V, then switches off at, say 2V, and repeats, would be appreciated.
I have some transistor ideas, but they don't have enough beta to have a 90 degree knee. Comparator solutions with hysteresis place too much load on my precious coulombs...
amkt6868
amkt6868
5 years ago
hello everyone please I need your I wanted to make permanent magnet generator but I don't how I can do it. Help me
lars.b
lars.b
6 years ago
Here is an excerpt from http://www.free-energy-info.com/Chapt2.html
"First and foremost, high performance can only be achieved with the clever use of power collection coils. These coils need to be positioned accurately and their power collection restricted to just a very short arc of operation by connecting them to, and disconnecting them from, the output circuit at just the right instant so that the back EMF generated when the current draw stops, actually contributes to the drive of the rotor, speeding it on it's way and raising the overall efficiency of the motor/generator as a whole.
Next, the shape of the magnets used is important as the length to width proportion of the magnet alters the pattern of it's magnetic fields. In direct opposition to the diagram shown above, the magnets need to be much longer than their width (or in the case of cylindrical magnets, much longer than their diameter).
Further, a good deal of experimentation has shown that the size and shape of the electromagnets and pick-up coils has a major influence on the performance. The cross-sectional area of the core of the pick-up coils should be four times that of the cross-sectional area of the permanent magnets in the rotor. The reverse is true for the cores of the drive coils as their cores should have a cross-sectional area of just one quarter of the rotor magnet cross-sectional area.
Now for some practical details. It is suggested that a good length for the power pick-up coils can be determined by using the “paper clip test”. This is done by taking one of the permanent magnets used in the rotor, and measuring the distance at which that magnet just begins to lift one end of a 32 mm (1.25 inch) paper clip off the table. The optimum length of each coil from end to end is exactly the same as the distance at which the paper clip starts to lift.
The core material used in the electromagnets can be of various different types including advanced materials and alloys such as ‘Somalloy’ or 'Metglas'. The power pick-up coil proportions are important as an electromagnet becomes less and less effective as its length increases, and eventually, the part furthest from the active end can actually be a hindrance to the effective operation. A good coil shape is one which you would not expect, with the coil width being, perhaps 50% greater than the coil length[...]"
lars.b
lars.b
6 years ago
"Now for some practical details. It is suggested that a good length for the power pick-up coils can be determined by using the “paper clip test”. This is done by taking one of the permanent magnets used in the rotor, and measuring the distance at which that magnet just begins to lift one end of a 32 mm (1.25 inch) paper clip off the table. The optimum length of each coil from end to end is exactly the same as the distance at which the paper clip starts to lift.
cblomquist
cblomquist
7 years ago
Great e-book resource for many zero-point energy projects. I am not the author, but it's got some really intriguing info and research.
http://www.free-energy-info.tuks.nl
There are those who have generated many kW using relatively small setups. Yes that's KILOwatts!
jetboy
jetboy
10 years ago
i am using 2x1x1/2 inch bar magnets and need to know the best size coil for my wind turbine, the gauge is 14 and am using 35 turns of two parralel strands to produce 12 volts
rwellsaction
rwellsaction
Answer 8 years ago
Hi Jetboy, the rule of thumb when building a generator is what ever size magets you use, that should be the inside diameter of your coil. The magnet should be able to barely squeeze through the inside diameter of the coil!
Jewson
Jewson
8 years ago
If your lazy you could get a dc motor and turn it manually and it will produce electricity. You could take it apart see what kind of wire and magnets are used and learn from it.
relic1974
relic1974
Answer 8 years ago
I'm looking at the neo lab magnets that are threaded so I can mount an array of them to a fixed surface. for the coils, I have found some of the surface mount IC design charging coils that handle quite a bit of amperage. with rectification and voltage regulation, would this be a way to get it done ???
coils here http://www.coilcraft.com/pfl.cfm
relic1974
relic1974
Answer 8 years ago
I am working on a project still on paper. I'm experimenting with charging a small Li-On battery and a supercap via inductance. Here's the jest of it, and I'm just wondering what type of magnets and coils I might need. I would need the smallest coils available that could still produce a few volts at low current applications.
I want to be able to make a generator for low voltage (3.5V DC or less) @ around 500-800mA
I want the magnets in a fixed position, and the coils (several of them) would be in motion continuously.
Induce this current into the coils to a Li-On charging circuit and/or a super cap for power storage.
ANY advice would be much appreciated, and I would share my results.
Ed Nature
Ed Nature
10 years ago
I'm a teacher looking to do extra-curricular electromagnetic experiments with his students. These are the same questions I have. I seriously doubt that these experiments have yet to be completed - probably 50 or more years ago. So where do I go to read and study? Don't have the time to conduct these exploratory experiments as this is not my primary job or responsibility - those of which suck up most of my waking hours each day. I and reader #1 are looking for simple guidance as to where we can find these answers. If graphs aren't available - just some rule of thumb stuff to get us going. The only answer I saw given was that the magnet should be as close as possible to the wire coil. Isn't there somewhere a set of graphs plotting variables such as size of magnet, strength of magnet, gauge wire, rotational speed of magnet, vibrational period of magnet, etc. - all giving amount of electrical output? Thus, for a classroom teacher - who can recommend the best size neodymium magnet with the right size magnet wire and number of loops and specs how to build the device, to be used in harvesting the kinetic energy of a moving river - or the wind outside (Beaufort scale up to 4) via a simple student built turbine?
Meat5000
Meat5000
Answer 9 years ago
Oh and also, you should look into the difference between SYNCHRONOUS and ASYNCHRONOUS and other induction generators.
In essence its all just waving magnets past each other.
Meat5000
Meat5000
Answer 9 years ago
Ed, I would advise starting with the simple 'nails and wrapped wire' motor experiment. Then, disconnect the power and hook the home brew genny up to a resistor and a multimeter, or a bulb.
If you are teaching secondary school I would say that wire guages, rot speeds etc are arbitrary. If what you make works then that is good enough. I would advise AGAINST using anything other than a standard lab magnet as anything with a stronger flux can easily lead to SERIOUS INJURY due to the currents that you can produce. Unless you are planning to power your lab, I'd say that any power produced would be a result.
What i will tell you is that it is the MASS of the MAGNET or ROTOR that in fact produces the biggest change in output. More turns of wire is better and the guage of wire is designers choice. Basically you choose a guage depending on how much current you expect to be producing. You can find this max current info on farnell datasheets. There is nothing wrong with getting a heavier guage than you expect, to be on the safe side. Aaaand it must be laminated. Just don't use thin wire or you'll start a fire.
There is no real rule of thumb when it comes to designing a genny; but the reason you can't find any info is because any change to any part of a motor/gen produces a change in the 'equivalent circuit' of that motor/gen and the results may not be as you'd expect.
The maths of a motor may look hairy but when you've learned it once you can apply it to most motors. Depending on the type of machine you are making, the number of "Poles" is important. If you want an idea of what you'll get out of it before you make it, the maths is really the only way. Otherwise its pretty much guesswork. This is your homework.
Start with a small weak magnet, make a prototype then you can use a more powerful magnet of the same dimensions once you have evaluated the safety aspect - WHICH IS OF THE UTMOST IMPORTANCE WHEN PRODUCING POWER.
Sorry for a late reply :)
haskinsmp
haskinsmp
9 years ago
I was looking into this as well. The best I ever got in explaining this is an Excel file I found somewhere. Perhaps with a little knowledge this can explain things for some and for others at least help.
atepinkrose
atepinkrose
Answer 9 years ago
I was looking at the document...what does the F mean?
Thanks
haskinsmp
haskinsmp
Answer 9 years ago
I am no Electronics Engineer, but I would say it was capacitance or F for Farads. If you look up Farad on Wikipedia it will help to solve the formula given (I/2rm).
brokengun
brokengun
11 years ago
These questions are not really specific enough. There is no "best wire size", etc. Basically it all depends on what you want to achieve, what voltage, what kind of power you are looking at producing, and what RPM the generator will be spinning at. All of these things need to be taken into account. I can't find specific places that will give you this info. I have seen it for a few various wind turbine designs but I do not have the raw equations to calculate your own alternator specifications. Really a lot of it is just trial and error. There is a lot of theory and science behind it all but in the end there are a lot of variables to consider. For example magnet strength and air gap. Not to mention the physical limitations of the materials. In general I will say that as a rule of thumb for axial flux permanent magnet generators, the hole in the middle of the coil is roughly the size of the magnet. You should be able to squeeze the magnet through the center of the coil. That seems to hold true at most all sizes of axial flux machines. Lots more to learn about alternator/generator design and theory. My suggestion: read, study, ask questions.
DimaWari
DimaWari
Answer 9 years ago
Try this link http://www.6pie.com/faradayslaw.php
kchaitanya
kchaitanya
9 years ago
can anybody help me in finding the size of the magnets to produce 240v in generator... i am planning to use neodymium magnets ... please this is my mail id .. krishnachaitanya.maruvada@gmail.com
cdcobre
cdcobre
10 years ago
I am searching for the same answers for a different wind generator I am tryng to create.
brokengun is 100 % right I am going  nuts with so much you have to put together.
Faraday laws in is a good way to start knowing about this topic.
this guy in youtube give me a great info just wear something to help with the bad audio on the videos an learn, it is fun after all.
how to wind copper coils tightly for wind turbine stators part 1 and 2
Sorry if I made any mistakes my language is Spanish.
