90Views9Replies
Author Options:
Blender modelling question? Answered
Hello,
I have two objects on the screen.
When I select one and press G, a large circle appears which alters both objects when I grab; this has not happened before.
I know that I must have pressed a shortcut by mistake but I cannot seem to find an answer on the Googles.
I've even gone through the process of pressing each key.
Could someone tell me how to return to normal.
 Thanks
EDIT; When I say normal , I mean, I need to get the Grab cursor back to normal( at the moment when I try to use it, it is a big circle, that effects everything it touches, rather than just the object that i want to move).
RampedUpDIY
RampedUpDIY
Best Answer 4 years ago
I think what you're dealing with is the proportional editing tool. https://www.blender.org/manual/editors/3dview/transform/transform_control/proportional_edit.html
Hope this helps. Good Luck!
FriendOfHumanity
FriendOfHumanity
Answer 4 years ago
Yeah man, you cracked it.
Super Duper thanks.
FOH
RampedUpDIY
RampedUpDIY
4 years ago
It's not acting like the paint select tool is it? (when you press "c" you can use a circle to select multiple objects) If that's the case then your keyboard shortcuts have probably been changed in the user prefferences.
FriendOfHumanity
FriendOfHumanity
Answer 4 years ago
Much thanks for the help; it turned out to be the proportional editing tool.
FOH
RampedUpDIY
RampedUpDIY
Answer 4 years ago
No Problem!
FriendOfHumanity
FriendOfHumanity
Answer 4 years ago
Hello Quadrifoglio,
Thanks for the reply.
My description may have been misleading;
It's not the moving that's the problem, it moves fine, it is just that so does everything else in the circle.
I can use escape to go back but the grab function will still be a big circle if I try to use it again.
I need the cursor to go back to normal grab function for edit mode.
That is a great link though and I will now go through it and it will help with Blender.
Thanks
FriendOfHumanity
FriendOfHumanity
Answer 4 years ago
Thanks for the help; it turned out to be the proportional editing tool.
FOH
